whatever my GTS4 would have had as standard so I can get the correct size tyres when I get larger rims
225/50/16? or 205/55/16? someshit like that. they both fit on a 16" R32 GTS4 alloy and give you the same rolling diameter from memory, cbf double checking to make sure tho.
yes skins we should go fishing!
we meeting up for fishing battles on our iphones? :P or u wanna do the real thing?
fishing battles first then the real stuff
then the beer
then we can do both at the same time battles and fishing
205/55/16 is stock R33 GTST tyre isn't it? .... so I would assume the R32 was the same?? or at least very very close??????QUESTIONMARKETY????????
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
    • @Rusty NutshI mate. Do you have a pinout diagram for the na neo auto ecu?
    • Yeah thats the plan now. 🤞
    • Have a chat with the tuner, you'd want to drive the car straight there.
    • My mechanic installed all the parts and then got it tuned which i think is around the corner from him
