cheers, I always lol when people think that an s13 is in some way slower and less capable than a r33
That's unfair though, 33s are boats.
S13s certainly plough a field better :)
they're a good engine, shame about the noise (and lack of cylinders)
yeah the noise can be ok with bigger turbo and decent exhaust, the more its muffled the worse it is lol, will never sound as good as a RB though...as for lack of cylinders pfftt 86mm x 86mm goodness, its the goldern ratio for revs vs torque,any more cylinders and you would end up with a silly little thing that doesnt make peak torqe till 6400rpm! :)
I love tractors now, i am seriously considering ditching the GTR when its rebuilt and focusing my efforts on the sil80
tristan likes this a lot, a hell of a lot :)
yeeh will never be as good as rb - but can sound tasty, oh and epic sr flutterzzzzzz
:) i was joking
dave and i just re did my zorst to sort out all the epic leaks - we used that high heat gasket goo and gaskets
Don't spose you know what the standard "3inch" gasket part number is? I CBF tracing the flange's and taking it in to super cheap
dave has it :)
does this mean the junker is coming out? not out of the closet - just out thursday?
dave has it :)
Depends..
I haven't order'd a de-pu$$y pipe yet, because I dunno if it well sell today on ebay, plus i CBF fitting the front pipe myself
I don't bother with any gasket goo or anything with exhaust gaskets...
just go into rapeco and ask for a standard 2 (or 3 if thats what you need) 3" exhaust gasket. They'll find it for you. Or an exhaust shop
Depends..
I haven't order'd a de-pu$y pipe yet, because I dunno if it well sell today on ebay, plus i CBF fitting the front pipe myself
i opted to be a pussy instead of getting a de-cat :)
i like that you're keeping it hahaha :) (or at least thinking about it)
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
