cheers, I always lol when people think that an s13 is in some way slower and less capable than a r33
That's unfair though, 33s are boats.
S13s certainly plough a field better :)
they're a good engine, shame about the noise (and lack of cylinders)
yeah the noise can be ok with bigger turbo and decent exhaust, the more its muffled the worse it is lol, will never sound as good as a RB though...as for lack of cylinders pfftt 86mm x 86mm goodness, its the goldern ratio for revs vs torque,any more cylinders and you would end up with a silly little thing that doesnt make peak torqe till 6400rpm! :)
I love tractors now, i am seriously considering ditching the GTR when its rebuilt and focusing my efforts on the sil80
tristan likes this a lot, a hell of a lot :)
yeeh will never be as good as rb - but can sound tasty, oh and epic sr flutterzzzzzz
:) i was joking
dave and i just re did my zorst to sort out all the epic leaks - we used that high heat gasket goo and gaskets
Don't spose you know what the standard "3inch" gasket part number is? I CBF tracing the flange's and taking it in to super cheap
dave has it :)
does this mean the junker is coming out? not out of the closet - just out thursday?
dave has it :)
Depends..
I haven't order'd a de-pu$$y pipe yet, because I dunno if it well sell today on ebay, plus i CBF fitting the front pipe myself
I don't bother with any gasket goo or anything with exhaust gaskets...
just go into rapeco and ask for a standard 2 (or 3 if thats what you need) 3" exhaust gasket. They'll find it for you. Or an exhaust shop
Depends..
I haven't order'd a de-pu$y pipe yet, because I dunno if it well sell today on ebay, plus i CBF fitting the front pipe myself
i opted to be a pussy instead of getting a de-cat :)
i like that you're keeping it hahaha :) (or at least thinking about it)
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
    • Does anyone on here know which wire on the GTT triple gauge pod harness is for the oil temp gauge? my sensor works fine but I upgraded the gauges to DEFI advance. And if I can simply piggyback off the oem oil temp wire to the Defi oil temp sensor wire that would make life so much easier.
    • Even face her a wash now that’s it worth more than my house
    • This was what I was invisioning, or Pete cutting a beer can up and hose clamping it around the catch can! Ha ha ha
