Need to take a fridge from Stafford to Aspley.
And Tas made mention of a GTR bonnet I might be able to get - Not sure where that's coming from, but it would also be going to aspley
:banana:
Too easy, we just gotta work out when I guess...
TECH QUESTION:
I don't want to hack up my front bar, are there decent half sized front mounts, or decent air to water coolers for the rb20?
Hmm... define hack up. I managed to find one on ebay that I could fit in the 31 without hacking any metal, just had to take some plastic off. Have a search on ebay, theres a remarkable variety of sizes and shapes :(.
TECH QUESTION:
I used to have an apexi one, return flow, about half the "normal" size you see on front mounts.
that one has been discontinued for quite a while. Have never seen another skyline with it on.
Hmm... define hack up. I managed to find one on ebay that I could fit in the 31 without hacking any metal, just had to take some plastic off. Have a search on ebay, theres a remarkable variety of sizes and shapes :banana:.
Part I - Sweet as bro!
Part II - Define "hack up"? I don't want to cut my front bar AT ALL. The front bar is probably my favorite part on my cars body. I want to keep it how exactly how it is with the slightest mod of changing the gay, useless yellow fog lights, to sans poof, usable white driving lights.
Actually that reminds me, i think what you want is a "Stealth" kit, which you can get for 32s/33s. These are designed to fit without hacking anything, and run the pipes through the stock holes and everything.
oooo I like the sound of "Stealth"!
It makes my pants tingle like there's a ninja in there!
LOL
Actually i've just been looking, it looks like there only around for boats :banana:
Your best bet is probably to measure how much room you've got in there and start trawling ebay
though once again it looks like r33/34 only, what i would do in that case is buy the stealth core then get Dan at ERD to knock you up some pipes to fit
assuming the stealth core is small enough to fit behind the 32 bar without cutting...
sheould be, i managed to get the generic gtr size chinese thing behind my front bar with out cutting
Another option could be getting either a r34 side mount, or maybe an ARC side mount. they are quite a bit larger than the standard ones
Or just man up and molest that front bumper.
But seriously you should be able to find a front mount that will fit in the stock bumper. There are hundreds of sizes out there and it will just be a matter of getting the piping to suit.
sup skins, my mangin mang
Mang. Just manging the usual type of mang.
Morning mangtlemen.
Anyone else get up for the gym at 530, only to fall asleep and wake up an hour and a half later? :banana:
Manglette
Mate in work said the same thing. I will have to dload it now that i can has internets
Oh and Morning Mangs
Mang
BAHAHAHAHAAHAHAHAHAHA! Imma paint it in John Deere colours and put an SR20DET badge on it
Sure, why not?
ESSS AAAAAAAAAAAAAARRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR!!!!!!!!!!!
I don't get it :(
do it mang! this series is just... chilling :(
You only like it because of the bewb drinking game
Where you gunna take it?
To the movies
Think i caught up...maybe.
Oh hai thur
hai2u
Sold your bucket yet?
LOL @ Telstra. Just had to ring up to cancel old phone line and she answered the phone something like this:
"Hi this is <-insert name of hot sounding phone girl-> on the Gold Coast. How can I help you today?"
I guess they want to make it quite clear that you are not talking to someone in india :banana:
    • Thanks, I'll shim that plug and hopefully it fixes it.  Yes still factory turbo for now, still have the misfire it's not as bad but still noticeable
    • I had someone check the CU, they said it was fine but it could be buggered  I was only running around 7-10 PSI on the dual stage controller, but my boost gauge is shit house and needs replacing so I'm not getting a true reading.  Then I ran from wastegate pressure as per Turbosmart but still have the same sort of issue
    • Yeah this is a thing. I've had mine setup like this for a few years now, works fine. If I dredge my memory bank, I think I had to do this after I removed my factory dash.  So you've tried it on gate pressure, I'm assuming this is the factory turbo? Did you still have misfire issues with that setup?
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
