no one here streams porn lol? loads quicker haha
nope, we just have sex with real girls instead of our hands*. You should try it sometime :D:bunny:
*except Jason. He meets fat old men on the intertrons instead
Don't call me Marty :devil:
Fine then, i'll call him Tim.
Hey Tim
:D
nope, we just have sex with real girls instead of our hands*. You should try it sometime :bunny::bunny:
Leave jack out of this
He's hot and your jealous :P
Side note :
Job application I just sent
Afternoon Dean,
Thank you for you rejection letter dated the 19th of Jan 2010. It is unfortunate but at this time due to high volumes of corespondance, I am unable to accept this. This rejection letter although is of a high quality and standard and will be kept on file for the next six weeks incase there is a change in my cirumstance.
Looking forward to starting work with you.
Sincerley,
Jason
P.S. You interviewed the guy three times ?
To: skins@secret.com
Subject: Workshop Technician Job
Date: Tue, 19 Jan 2010 12:58:55 +1000
Hello Jason,
Thank you for submitting an application for the 'Workshop Technician' position which I advertised in SEEK.COM.AU. I have been impressed with the volume and quality of applicants who have recognised this opportunity. However; it is my responsibility to screen all candidates and present a shortlist for the owners to consider. The very least I can do for you is keep you up to date with your application. Late yesterday afternoon we interviewed an applicant for the third time and were confident in making an offer of employment. The offer was gratefully accepted and thus the advertised position is no longer available.
Once again I thank you for your application and hope you will allow me the opportunity in the future to place you into employment. If you see a position I am advertising I welcome you to send an application.
Dean
www.cantsay.com
dean@shhh.com
PO box somethimg
Mt Gravatt Plaza
QLD 4122, Australia
This e-mail is for the use of the intended recipient(s) only. If you have received this e-mail in error, please notify the sender immediately and then delete it. If you are not the intended recipient, you must not use, disclose or distribute this e-mail without the author's prior permission. We have taken precautions to minimise the risk of transmitting software viruses, but we advise you to carry out your own virus checks on any attachment to this message. We cannot accept liability for any loss or damage caused by software viruses.
I'll let you know if I get anything back :D
cant do until im married, muslim bro lolz,
porn is all us moslems have before we get married :devil:
porn is all us moslems have before we get married :D
Hahaha, pretty sure the koran says you can't drink alcohol either.... May as well break another rule...lol
    • Well, yes, every CU on the bus is available via the Consult port, but whether the scanner you are using is capable of talking to the TCU, the ABS/TCS modules, etc etc, is what is at question here. Many of them are only for engine codes. So, if you have one of those, you won't know if the ABS is having a bitch.
    • That's now. R chassis Skylines come from a time when the tolerance in the ADRs was a bit more....slack. My car, on 235/35-17, which is damn near the exact same size as the original 205/55-16, is pretty much bang on correct indicated speed across the whole legal range. That's demonstrated with constant speed run over 5km, and GPS speed. It's just the luck of the draw. My particular speedo head has to be the thing that is "calibrated" that way, because everything else (the diff ratio, the gearbox and the speedo drive**) are all same same as most other Skylines. **OK, so the speedo drive is a Navara unit to drive the R32's cable, not the electronic unit than an R33/4 would normally have with teh same gear on it. Otherwise, I applaud your OCD tendencies, and I would do the same if I needed to.
    • Not too sure, I believe the Nissan consult port does everything? Also just filled up the reservoir to full and the light is still on. The float seems to move up and down fine.
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph on 255/40 17, so again conservative Google says manufacturers need to set the speedo from 4 to 10% slower than actual road speed.....for safety.....and compliance  After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
