i was jst kiddin about the moslem part guys, ive had my fair share of the punani bck in the good old high school days but havent relly found the time once i got to uni, even if i do score im too pissed to remember anythin the next morning, need to sober up, this sem is going to be extremely stressful.
is it just me or can i hear a cricket chirping ?
*face palm*
fag
No u.
Side note :
Job application I just sent
[more stuff here]
I'll let you know if I get anything back :)
That is quality posting right thur.
cant do until im married, muslim bro lolz,
porn is all us moslems have before we get married ;)
Sucks to be you?
Hahaha, pretty sure the koran says you can't drink alcohol either.... May as well break another rule...lol
No wonder they all blow themselves up.
if the hymen doesn't break, you can't count it on the score card :)
Farkin lolskates.
morning mangs
hi colin, hi josh
Sup biznitch.
I took the filter off my phone line last night and got 800KB/s dload but when downloading from anywhere but speedtest it's still slow as f**k. Going to call TPG tonight. Couldn't be f**ked last night.
Sup biznitch.
Are you talking normal downloading or torrents/p2p. torrent speeds can depend on a great many things, so might not be a problem with your line.
f**king score. I got Monday off. Win.
Same. sexy time?
morning mangs
hi colin, hi josh
Morning ;)
Sucks to be you?
lmao
I hate u
Same. sexy time?
Jealous
So whos the best person to talk to in regards to pumping gaurds ? I dont really wana do it but 5000km from a set of bridgestone potenza's isnt really good on the wallet ;) Also once the coolers on ima need the extra rubber on the ground :)
Same. sexy time?
normal dloading is still slow which is probably normal. Haven't tried any torrents/p2p yet. Probably just shit servers that I'm dloading from rather than my line. Gay.
http://www.guardrolling.com.au/ that is the guy that I used to roll my guards. Not sure if he's any good with properly pumping guards. I would probably go see a panel beater if it needs to come out a fair bit.
So whos the best person to talk to in regards to pumping gaurds ? I dont really wana do it but 5000km from a set of bridgestone potenza's isnt really good on the wallet :) Also once the coolers on ima need the extra rubber on the ground ;)
I has a hammer and pliers :)
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
    • Well, I was using ECUTalk software if that helps? Not sure if that only can see engine codes? Is there any other software I could give a try? Or any way I can get a blink code?
    • I never touched it, it should have. I'll try to give it an adjust. With IACV plugged in, it idles at around 1120RPM on average. Max 1200 RPM, Minimum 1025RPM before it starts dropping right before stalling. Took the data from the Nistune logs.
    • Thats what im trying to solve bro  no one with aem tuner experience would advice  much appreciate
