I have a mate that runs his own spray shop if you have no luck with that guy let me know and i will see what my mate can do for you, he loves custom stuff
he's not looking for an apprentice by any chance is he? :D
Oh yeah that would be awesome, I need to find out if its possible to bring the rear gaurds out about 20mm and how much ide be looking at?
If you find someone who can - let me know please? I want to flare my guards :D
I have a wall mount aircon I'm not using if you're interested. The money can go in my tyre fund :D
Wall mount? Or window mount?
Details/specs/pics.
Could be interested, I am on the hunt for one for the computa room, but spotted the 6kW monster which would be perfect for the garage. If yours is suitable for either room, v. keen :)
Details/specs/pics.
I'll have to swing past Mum's house later and get requested info and pics for you :D
and window vs wall - wherever you want to mount it. I had it mounted in (through) the wall, but they can be mounted in the window as well. Just depends on what you want to do.
There are no brackets though, it's just the unit. Brackets got lost on either the move to, or the move from Townsville.
yeah cool. Wasn't sure if you meant like a split system that mounts ON the wall with the extra shiz outside, or just one that goes through a window/wall. I'm way to lazy to put it through a wall, but if I can window mount it, all good :D
Definitely keen if you can get the specs on it (especially capacity). Don't need the brackets, as long as it has the outer casing it's all good brother.
FFFFFFFFFFFFFUUUUUUUUUUUUUUUUUUU I might have to buy a DLink wireless card, since it seems no one else makes a decent wireless N card :)
That fkn sucks
oi yo martin, and anyone else who cares..
turns out the 180s ecu was chipped from japan..
so instead of her going on the dyno to sort out timing, she went on the dyno and got tuned ;):D
AAAAANNNDDD
shes a f**king handfull to drive now :)
f**kin schwingggyyyy. Post up a sheet yo!
Colin...Guess what i did too your sister!!!!
I'm gonna be in the shower and be all like BYYYAAAAAA.....then I'm gonna take my wife and make love to her like BYAAAAAA. Chappelle is king
    • Basically your tuner needs to drive it for the 30 min (or whatever) to create the same conditions then check the ECU settings and sensors at that time. They may not be excited to because that takes them 30 min rather than just opening the bonnet and seeing the problem straight away.... Hot start is generally not as tricky as cold start, but there would be a table for fuel enrichment vs coolant temp as a starting point
    • Yeah, they all cant say anything for sure as everything is working fine . Said unable to find an issue untill it stops again. Could mist likely be CAS wiring or IAS valve issue but again not 100%
    • Who tuned it? Have you spoken to them about the hot start issue yet?
    • injectors were upgraded (1000cc), stock turbo high flowed, return flow infercooler and ecu nistuned before tuned
    • Injectors? Note, there is no way that I would run E85 on stock injectors. They are too small.
