Check out this email I just received from an engineer at work . . .
He says
"Sorry but I just realised that the last design I sent you still has the cornered corners on it. This .arch is called exactly the same but has the rounded edges, which is what we want"
I say
"Cornered Corners? As opposed to un-cornered corners right ?"
He says
"have a look and you will see what I mean. cornered corners as opposed to rounded corners.
f*kin knew someone would be a smartass when I wrote that... f*kin knew it would be you too Dan... can't help yourself... can't believe I wrote it anyway"
I say
"I think you mean chamfered corners"
He says
"Chamfered is what i will say next time.
Thank you for the destructive criticism Dan. Always there for me.
I'll just go knock myself out then."
Chillin at the train station with my abo homies yo. Keepin it real.
Lol, hope you're packing man.... I wanted to actually come tonight. I went over to pick my car up, assuming the front bar and some other things will be fixed and its fkn worse than before.... Fkn repairers....
weak moistcoils weak!
Oh you know exactly what to say to make a girl blush!! :blush:
How come you're not out there???
Don't drink all their goon now.
@John thanks for the lift.
( note to self don't open beers straight after epic mountain run style driving )
@Tas thanks for looking at my car really appreciate it
@Skins stop typing and drink the damn beer
You ragging on me? MF/
NP!
took a quick pic for u before i left work!
I like your steering wheel looks baller!
Edited by Redsuns88
NP!
Dry ice to get the deadner out ? Pfffttt thats the gay way. Fire is the way of the future.
No worries man, anytime :D
lol we already discussed that when you were getting out of the car! Did you forget on the epic walk back to your house from where I dropped you off? :)
But the walk was so long back to my place I forgot.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
