Check out this email I just received from an engineer at work . . .
He says
"Sorry but I just realised that the last design I sent you still has the cornered corners on it. This .arch is called exactly the same but has the rounded edges, which is what we want"
I say
"Cornered Corners? As opposed to un-cornered corners right ?"
He says
"have a look and you will see what I mean. cornered corners as opposed to rounded corners.
f*kin knew someone would be a smartass when I wrote that... f*kin knew it would be you too Dan... can't help yourself... can't believe I wrote it anyway"
I say
"I think you mean chamfered corners"
He says
"Chamfered is what i will say next time.
Thank you for the destructive criticism Dan. Always there for me.
I'll just go knock myself out then."
Chillin at the train station with my abo homies yo. Keepin it real.
Lol, hope you're packing man.... I wanted to actually come tonight. I went over to pick my car up, assuming the front bar and some other things will be fixed and its fkn worse than before.... Fkn repairers....
weak moistcoils weak!
Oh you know exactly what to say to make a girl blush!! :blush:
How come you're not out there???
Don't drink all their goon now.
@John thanks for the lift.
( note to self don't open beers straight after epic mountain run style driving )
@Tas thanks for looking at my car really appreciate it
@Skins stop typing and drink the damn beer
You ragging on me? MF/
NP!
took a quick pic for u before i left work!
I like your steering wheel looks baller!
Edited by Redsuns88
NP!
Dry ice to get the deadner out ? Pfffttt thats the gay way. Fire is the way of the future.
No worries man, anytime :D
lol we already discussed that when you were getting out of the car! Did you forget on the epic walk back to your house from where I dropped you off? :)
But the walk was so long back to my place I forgot.
    • Yea got me coppers. Bad news is I just put them in and the car still has the light and shakes. I also noticed I hear like rattling coming from the exhaust piping right under me. Does 21 also have a possibility of being O2 sensors?   So, coil packs are good, the harness is good, the MAF is working, and obviously the spark plugs just replaced and working.
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
    • @Rusty NutshI mate. Do you have a pinout diagram for the na neo auto ecu?
    • Yeah thats the plan now. 🤞
    • Have a chat with the tuner, you'd want to drive the car straight there.
