Dead thread dead thread dead thread dead thread dead thread
those words have just lost all meaning to me :D
not dead now you just breathed some life into it
nice fresh minty life
I figured, i got this in my head all day, you all can burn in hell with me.
(dont know how to link youtube vids the fancy way)
you'll have to give me the gist of it no youtube at work :D
skins where do you work?? And yeah no youtube on my phone when out in the valley... Please explain the vid for me!
Also..... anyone have experience with haltech or emanage? I can get an emanage blue for pretty cheap off a mate, but apparently they're a pain to install + tune (anyone here know someone who can tune them?)
On the other hand, I know nothing about the haltechs.
I was wanting to install myself, I'm pretty handy....... but won't be able to tune.
Debate......... NOW!
Haltechs are the shit and have the plug n play harnesses for around $100 extra. The platinum sports 2000 are around 2k for the unit itself though and will be overkill for a stockish application. If your cars basically got a stock turbo and you plan on keeping it that way go either the nistune or a toshi remap or equivalent. All comes down to how much you wanna budget for and the application. Wolf have the v500 and v4x something. Pretty sure both can come complete the harnesses for a 33 too. I honestly wouldn't bother with an emanage or an safc though considering the cost of getting a nistune installed and tuned is around the 1k mark.
Also PFCs are f*cking ancient. Do these people run 486s with their 18k dial up modems to connect to the interwebs as well?
Mad analogy! Windows 3.11 FTL :D ....just like pfc's
Brisbane City Council. If you could it work. :D I work in the water industry.
i need motivation to work on my cars
pffftttt motivation... just drink beer instead ;)
Morning mangs. Another beautiful day at work.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
