If you ever did that to a caterham, i would kill you.
We used to have a genuine Lotus 7, dads been on the search for a caterham though
Genuine lotus 7 i wouldnt but I don't see the harm in putting one in a caterham. No different than putting an SR, 4AGE or F20c in it.
Would go well in a caterham or a radical or something small and light like that. Would still haul arse in an s13 aswell lmao.
yep 400hp in a s13 goes quite nicely! Though i just read the reccomend a rebuild every 30 hours? screw that
Lost that SR Love? :D
Never! but V8s with ITBs are sex, and when was the last time you saw a v8 s13?! It would be an interesting project. Perhaps you need one for your mower?
afternoon ;)
:happy:
afternoon :D
hey mang, coming out tonight?
Hahahahaha, I like your thinking. Might be a plan if the turbo option doesnt work out :happy:
Ive still got the SR turbo here if you think the mower could push it!
FYI caterham is made under license from Lotus.
Technicaly speaking a caterham is a Lotus...
Technicaly speaking you are a guy but every one knows thats not really the case! :happy:
I'm willing to give it a go :D. If you're going to come out tonight, bring it along plz ;)
Will do
But a real lotus 7 hasn't been produced since what, the 60s? Early 70s maybe? It would be a genuince classic
caterhams are a dime a dozen (figuratively speaking :happy:), and they put any of about 100 engines in them from factory anyway.
Kinda like 32s. They are everywhere, everyone hates them, not worth a penny. But 31s: they are classics. Something special. Everyone loves them. Worth a fortune. Etc. :D
<3
<3
Caterhams aren’t, PRB’s and Westfield replicals are everywhere.
A current Caterham is still a $100k car..
a 70's - 80's Caterham will bring anything from $30k - $70k
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
