Horny weasel, nahrung is indeed food!
ah, weasel. of course.
Yes, I figured as much. I would have said "trinken Sie Bier und essen Sie wurst", but only because that is the only german food word i remember...
how do you "tell" a person a spare "wiesel"??
LOL. No Jase, I don't need you to tell me a spare weasel.
busted :)
sooo bored at work
Never been to the german club. Is it good ?
Its great, food isnt as cheap as it used to be but its tasty and the beers are awesome, Erdinger on tap FTW!
I haven't seen any busty beer wenches there unfortunately, most of the bar staff seem to be dudes :D.
There are a couple of v. nice waitresses in the resteraunt though :)
Theres a few good beers on tap, and a sh*tload in bottles.
aren't you supposed to be at work?
yep :)
There is a place on bunya ave that might have a injector for you cheap. Just can't think of what they are called.
injector or coil pack?
when's work?
coil pack you know what i mean.
work ? now apparently.
i can get you some goo stuff that will insulate it if you like. can get it today
That'd be awesome if you could. The tape stopped it a little bit, but not completely. When I took off from Coles last night I hammered the throttle and the car nearly died! It was like driving a rotary with more than one person in it :)
I did some limiter bashing on the way home though to make sure my red lines were still ok. Still gets up to 9, so it's not suffering as much. Steep hills aren't killing it as much when I put the power down now. But it's still SLIGHTLY laggy. So better insulation is probably not a bad idea. I am just so sick of ripping all that shit out to get to the valley :(
Fire!...good...
You're just saying that because you want me to need water to put the fire out...
I am just so sick of ripping all that shit out to get to the valley :)
Leave the valley cover off
Yep it's my cunning plan.
I'll get some goo for ya john.
    • If your tuner can't make the car idle like factory, I'd get a new tuner. These injectors are fantastic and I'd have very serious concerns about a tuners skill set if they couldn't get them to idle well.
    • It's highly likely you will find something. Alternatively, a quick design and order online from chaina and you'll have a perfect solution
    • Idle Lambda target is off by .4 but I reckon the VE table is not correct. If my tuner has no issue using these injectors I will keep them, they are good quality after all
    • I already have an Apexi. Just wondering if it is worth putting in something new since the Apexi is likely well over 10 years old, if not 15. I know the injectors work but they already run at less than rated fuel pressure to make them work properly and idle is basically 1% duty cycle or less. Could be better
    • Nice, I would never have thought in that direction. The actual motor is a cylinder....I wonder if there are any cylindrical heat sinks with the right ID  (and if there is clearance to other components). I think adding airflow is still a thing as well....will check it all out next time it is in the air. Wish I had a hoist...
