Horny weasel, nahrung is indeed food!
ah, weasel. of course.
Yes, I figured as much. I would have said "trinken Sie Bier und essen Sie wurst", but only because that is the only german food word i remember...
how do you "tell" a person a spare "wiesel"??
LOL. No Jase, I don't need you to tell me a spare weasel.
busted :)
sooo bored at work
Never been to the german club. Is it good ?
Its great, food isnt as cheap as it used to be but its tasty and the beers are awesome, Erdinger on tap FTW!
I haven't seen any busty beer wenches there unfortunately, most of the bar staff seem to be dudes :D.
There are a couple of v. nice waitresses in the resteraunt though :)
Theres a few good beers on tap, and a sh*tload in bottles.
aren't you supposed to be at work?
yep :)
There is a place on bunya ave that might have a injector for you cheap. Just can't think of what they are called.
injector or coil pack?
when's work?
coil pack you know what i mean.
work ? now apparently.
i can get you some goo stuff that will insulate it if you like. can get it today
That'd be awesome if you could. The tape stopped it a little bit, but not completely. When I took off from Coles last night I hammered the throttle and the car nearly died! It was like driving a rotary with more than one person in it :)
I did some limiter bashing on the way home though to make sure my red lines were still ok. Still gets up to 9, so it's not suffering as much. Steep hills aren't killing it as much when I put the power down now. But it's still SLIGHTLY laggy. So better insulation is probably not a bad idea. I am just so sick of ripping all that shit out to get to the valley :(
Fire!...good...
You're just saying that because you want me to need water to put the fire out...
I am just so sick of ripping all that shit out to get to the valley :)
Leave the valley cover off
Yep it's my cunning plan.
I'll get some goo for ya john.
    • Messing around with. Twin kit for. Rb30/26
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
