for today and the rest of the week i am the workshop controller!
this is all
What type of workshop ?
Place that makes beer ? :P
Place that teach strippers how to dance ? :P
get your angle on!!!!
Jason:
Mechanical workshop, luxury car, i seem to be the most senior mechanic, so with the normal controller away im it.
ALSO.............
Would like to take this moment to thank martin (smity42) for driving to my house, removing parts from my project car, then driving 30km in rubbish weather (heavy rain) so i could have working wipers, then staying while i fitted them (and failed a couple times) then following me home.
Cheers very much, i owe you
ALSO.............
He's probably still feeling guilty from taking all those photos of you napping at the cricket
nom nom nom :)
ALSO.............
martin you're a sex cadet, and a top mate
but i must say - sif need wipers :)
man up dan
nom nom nom :)
on a quick side note, just before i go to bed, nom nom apparently, in thai, means boobies
nom nom nom, would therefore be three boobies?
WOW! Enough posts to multi-quote! :)
dear nismoh, dan, martin, and anyone else who cares :)
<3 astro
Nice job! So no excuses left to not come out on thursday this week?
ALSO.............
You forgot to mention the fine piece of JB I abandoned in order to save your sorry a*se :)
Nah no problems dude :)
Not at all :P that was thoroughly deserved.
I'm pretty sure I still owe Dan a few hundred favours in the grand scheme of things though...
Haven't had to split a post for a while...
I know :P
and a top mate
I know :D
man up dan
Normally I'd agree, however on the trip over there it was f*cking pissing down, couldnt see 2 feet in front even with wipers. However by the time we actually got the wipers repaired and left the carpark, it was mostly gone :)
3 sets of boobies would be better...
P.S. Where is thread for German club meet hey? ;)
three boobies! :)
wow :)
You say that now, but I bet if you saw a chick with 3 boobies you wouldn't like. Its not natural...
For those who have a interest or for those who don't
At current there is
4500L/s of sewage leaving brisbane.
Pretty boring really.
Why is it leaving? What did you say?
That's how we do it. It's the easiest way.
Sounds like a good system tbh
this is all
Is that like the fat flamin mongrelroller?
dear nismoh, dan, martin, and anyone else who cares ;)
<3 astro
:) Good to see you're out sliding again. Gimme another 5 months :P and I'll be out there with the cop :)
ALSO.............
I feel the love
Shock horror!
+11ty Although I won't be there.
You forgot to mention the fine piece of JB I abandoned in order to save your sorry a*se :D
:) You are a better friend than most good sir
cbf multi quote so:
Here be internets!
I see skids! <3
'sif abandon JB :) Dan could have waited. He could have had another nap to pass the time!
3 boobs is too weird... I +1 with the 3 sets suggestion. But they need to be big sets. And attached to JB.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
    • hahah when youtube subscribers are faster than my updates here. Yes some vid from the day is up, here:  Note that as with all track day videos it is boring watching after the bloopers at the start.  The off was a genuine surprise to me, I've literally done a thousand laps around the place and I've never had instability there; basically it rolled into oversteer, slipped, gripped and spat me out. On the way off I mowed down one of the instructor's cones and it sat there all day looking at me with accusing cone eyes as I drove past. 1:13:20 was my fastest lap, and it was in the second session, 3rd lap.  It (or me!) got slower throughout the day as it got hotter.
    • It sounds like you want what the Toyota Landcruisers have for their roof racks. Wanna know what you end up with? Rust holes in the roof, and water everywhere...
    • Discovered today that if I select reverse first and take my foot off the brake, then select drive, the drive indicator light works and so does the tiptronic gear indicator.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Does anyone here have any ideas?   Cheers guys
