Does it really contain corn like the rumors say? :(
Yes. And if you can figure out a way to put it back on the cob, you'd be a macsquillionaire.
skins eats the corn.. makes his guns so lovely
DES and TROY will hurt you.
now you know.
And knowing is half the battle!!
Yep sure does. I know things about stuff and stuff about things.
Hey John, I hear that Euromarque Brisbane are hiring apprentices
If you want to be an apprentice to a bearded terrorist and work on dodgy POS alfas and fiats all day that is...
Steve Jobs is a flamin mongrel.
I hate him so much
@ Colin - have you done any work on the GTR yet since it's been off the road?
Cleaning it doesn't count :)
Morning post :)
Where's my dirt ?
I woke up with one of those too
That's what she said
morning poast
Mang
Mature age apprenticeship?
Bahaha . . . So a standard morning then ?
Where's my dirt?!
Would be a first for me
That's what she said.
This forum = poor form :D
Nah...your just not trying enough
*insert whore here*
...wait, that isn't right :banana:
Close though... here is a mickey mouse badge :D
and 2000
the end.
Sure, why not?
Where's my dirt?!
double LOL
:D:bunny:
F*ck yeah XF, always wanted a mickey mouse badge :)
and 2000
Well done!
the end.
Post of the week, for sure :banana:
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
