@ Colin - have you done any work on the GTR yet since it's been off the road?
Nop. Too hot n too lazy when ever I go home for the weekend. That and I've had no cash to chuck at it yet. Still got 20 weeks. So plenty of time yet lol.
I hate him so much
Cleaning it doesn't count :D
Where's my dirt ?
That's what she said
Mang
Mature age apprenticeship?
Where's my dirt?!
That's what she said.
Nah...your just not trying enough
Close though... here is a mickey mouse badge :D
and 2000
the end.
Cleaning counts mofo.
I'm out for tonight guys... picking up a girl or two and going to watch my mate dj in the valley :)
The Friend Zone. You are in it.
Morning Mr. Mandawai Udipingu
Morning Pom
Sup mang. What mangin today?
well i lie, i msgd dan as i figured you were with dan..
I'm still confused :ermm:
I'm sorry that dan dindn't respond to ur msg. Not sure why it's my fault but :)
*starts cutting*
yeah tgif I spose. Dunno what I'm gunna do for the weekend though....
Imma going to look at C210s, guns, etc
and mebbe move the workbench from the shed up into the garage
Hey all.... what's news?
No u.
*starts cutting*
C210s eh. What are you going to do with it? Restore? Epic conversion? Rust in backyard?
Yay ordered my new black shift & handbrake boots today :ermm: Finally can replace that horrible white crap thats on there.
Then all I need is my front mount and itl be ready for the HPI photo shoot :)
wow you fo-real?
nice work man!
Yeah whitey hooked it up for me :) Got a set of 17's wit shitty tyres off a mate too so I can bag it up for the shoot ! Cant wait :ermm:
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
