You're the kind of guy that in the days of yore, bards would have written songs about, and sung of your tales to their fellowkin over pints of the town's finest ale <3
I went through that thread, and a few things I googled. It appears my little trap door servo is of teh rooted. I seem to have rigged something up for now (cardboard isn't flammable isn't it? :blink: ). The test shall be shortly when I have to go out, and the engine is running.
I actually got awesome temp readings from all my sensors, so maybe all I need for my AC to work is a new compressor :)
glad it was helpful mate!
I have earth tones on today
ohk ohk well so we dont match ill go for shallow ocean blue turtle neck with a pair of arctic ice shelf pants
Did you just ask the closest female for the most gayest items to post
lol :)
im in the computer lab - i came up with that shit
i got another one,
when we are out i can get a 6pm winters sky navy scarf to compliment turtle neck
lolzz
my lunch was good, aside from the fact that a work mate spilled 2 schooners in my lap....but i got to come home so i guess that was win after all!
    • Resizing injectors in Nistune can be done a couple of ways, and there are a couple of ways that you can make a mess of it. The tuner needs to be really aware of the effects of whichever approach he uses (either K, or TIM). They are both easy enough to "get the injector size right" to run the engine. But little details like old start enrichment and hot start are affected differently, depending on which boxes you check.
    • Pretty safe to say almost everyone that has tuned their own car has experienced this issue. The difference being that we have our laptop in the car and when it happens, it's literally 10 seconds of tuning to sort it.  Would you be happy to plug in your laptop and sort this yourself? It is a very simple process and there is no risk of harming your engine (if you are worried about that).
    • Yeah thats the next step now, either they wil or i will take out for a drive to work and go straight their after work and see is we get the same issues 🤞  thought i try my luck here too, never know someone else might have had the same issue but thanks for the reply
    • Basically your tuner needs to drive it for the 30 min (or whatever) to create the same conditions then check the ECU settings and sensors at that time. They may not be excited to because that takes them 30 min rather than just opening the bonnet and seeing the problem straight away.... Hot start is generally not as tricky as cold start, but there would be a table for fuel enrichment vs coolant temp as a starting point
    • Yeah, they all cant say anything for sure as everything is working fine . Said unable to find an issue untill it stops again. Could mist likely be CAS wiring or IAS valve issue but again not 100%
