Getting the timing belt done with adjustable cam gears as well as a n1 water pump, harmonic balancer, crank and cam seals. The clutch is been replaced with probably a twin plate at this stage to handle the up and coming upgrades, probably with a lightened flywheel. Also doing split fire coil packs, maybe hks twin power system and installing a vipec ecu all before it gets dyno tuned. So should be good for approx 300 at all four wheels.
From there I will have to look at upgrading the fuel pumps and turbos all before the intercooler is changed out as everything is stock
Sounds good man :D
it was a 14 year old, 55kg aboriginal kid at work, and he only did because he knows that i am not allowed to crush him to death, or i will lose my blue card.
no serious damage, but fark i was pissed off.
Farken lol.
i know a bloke you can tag in, he's about the same weight a little older, he's also aboriginal.
Do it. I can sell tickets :D
Sounds good mang. Be careful running too much boost through the stock turbos they will most likely die with anything more than 1 bar.
I spy something in the back of that photo that looks familiar.......
Detective Dan strikes again?
Manging Morns
