Getting the timing belt done with adjustable cam gears as well as a n1 water pump, harmonic balancer, crank and cam seals. The clutch is been replaced with probably a twin plate at this stage to handle the up and coming upgrades, probably with a lightened flywheel. Also doing split fire coil packs, maybe hks twin power system and installing a vipec ecu all before it gets dyno tuned. So should be good for approx 300 at all four wheels.
From there I will have to look at upgrading the fuel pumps and turbos all before the intercooler is changed out as everything is stock
Sounds good man :D
it was a 14 year old, 55kg aboriginal kid at work, and he only did because he knows that i am not allowed to crush him to death, or i will lose my blue card.
no serious damage, but fark i was pissed off.
Farken lol.
i know a bloke you can tag in, he's about the same weight a little older, he's also aboriginal.
Do it. I can sell tickets :D
Sounds good mang. Be careful running too much boost through the stock turbos they will most likely die with anything more than 1 bar.
I spy something in the back of that photo that looks familiar.......
Detective Dan strikes again?
Manging Morns
    • This is aem disk setting in aem tuner and still 180 dgree off or ignition on exhaust cycle is it from cas it self as cas seems wouldn’t fit in cam shaft if wrong position and wiring been verified any ideas
    • Oh yeah that would work excellent. Should be the same diff housing & everything. Shoot me a text or call me 260-750-2246 -Cody
    • Oh right, I didn't realise it was your car. Please do! Makes me feel better about mine. I also have a big scrape on the front left bumper where someone presumably used the wall to guide the car into a parking spot  But somehow all the funds go towards mechanical things and the cosmetics stay forever unfinished... Interesting, I don't think I have seen it before. But after seeing @PranK's rusty roofline on the BMW I'd probably leave it alone. Wouldn't want water to get in there.
    • Thanks mate, thought you might know the answer.
    • Infiniti US are teasing a manual Q50 as a way to refresh a (very old) model. https://torquecafe.com/manual-performance-sedans-arent-dead-yet/ Can't be too technically difficult given the Z has the same motor with a manual gearbox......here's hoping there is a JDM version we can import here, that would save me a world of headaches
