not sold by the 34 spoiler on 32, i like them clean with no spoiler - or an epic GT wing :(
I have no spoiler, however for the track i think i am going to get an epic GT wing
as a brand whore i would go for cusco
high five! u can buy a 3D carbon wing thats pretty epic the others look like those super cheap ones
the 3d carbon wing can bolt to stock GTR R32 points with a 232mm bracket :( looks the same as the origin wings
its pretty nice
its pretty nice
that is pretty excellent, its on the list
so now my need to get list is
Surge tank
Brembos
R33 GTR wheels with Re55s
That wing
Most C-west wings are specific i dont think they make any for the R32/33 mainly for the newer cars now which sucks.. the wing for the supra and 350z are pretty much
but GT wings in general are all 3d GT style.. i believe its only voltex and a few others make different styles for each cars..
saying that though voltex are fkin exy but the quality makes up for it
Brembo's are nice.. gonna source the Vspec R33/34 brembo's ? or F50? i think i saw some F50 going around.. but its too expensive for what their worth..
i like Willwood but still unsure at this point of time..
I heard the Willwood brakes are awesome and are one of the cheapest sets you can get. Definately worth a look
prolly just R33 brembos, had them on my other r32 and i was pretty happy with them, if they dont work i will give alcons a run
Lol, poor josh, lowballers on SD trying to lowball him, "oh you only paid $500 for a pair of them" crying cause he wants $3k for 6 awesome offset rims.
Josh, make them 17" and you will have a buyer here.....
how abt u buy my brakes broad minded person
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
