Chicks love scars martin, just remove the stiches yourself at work tomorrow.....
Skins, put me down for a DAMBUSTER TOUR!!! im keen!
John:
The VG will fit in, has been done before on a 32, the only big problem will be a custom/modified sump to retain the 4WD system, from memory the VG30 is similar in electronics to the rb25's so wiring wise it won't be too much of a problem, Kev can make a plug and play loom up for cheap money!
Gearbox, the vg30 bellhouse bolts onto the rb25det box so if the gts-4 box is a same bolt pattern as that it will bolt straight up. VG is possible, will just be more expensive.
VQ's to retain the 4wd will need alot of work, custom bellhouse for one, if you want to drop the 4wd then buy a vq35 6 speed, only $2700 or so from option 1. VH's need custom bellhouse unless your a girly man and want an auto track car, which if thats the case, sell and buy a HSV.
Anythings possible, just cash involved, cheapest option and best bang for buck, RB25DET conversion with the 4WD system, swap sumps, modified wiring loom and away you go.
Or cheaper again? RB25 turbo on the 20, front mount and boost controller
John:
DAMBUSTER TOUR
FULL
More important note :
Morgan will not be attending B&R tomorrow
I repeat
That is all.
Sad, sad day
SOMERSET DAM TOUR ( update )
Maximum of 8 people at a time.
Date and time to be nutted out.
Let me know who's interested and we'll go from there
The end.
:P
Oooooooooohhhkkkkkk I'm with you now man. I'm in for a weekend depending on when obviously.... may or may not bring someone, depending on numbers, it's up to you completely dude.
hey guys,
names callum,
ive been on sau a while now but im not actually on it much, damn uni study lol
anywho just thought id put my hand up n say id be up for a cruise.
im located around the mt ommaney area if anyone knows that area.
cheers guys
hopefully some fun drives to come
hey guys,
names callum,
cheers guys
pfftf mt ommaney :blink:
tommorrow night at baskins n robins at indooroopilly along moggil road usual meet up @7.30 till late
he meant to say CHAPEL HILL. It's just past the Lexus dealership on Moggill Road. Get there early to secure a chair!!
hahaa i know where it is, i dont live under a rock.
mind u uni does kill all social life
righty dokie then! less info next time :blink:
technically that area is boarder line chappel hill/kenmore/indooroopilly
i like to choose the better of them and have a suburb where people cant really say it :down:
it's not border line jack and or shit. The official boundary for Indooroopilly finishes on the western corner of Rennies Rd. Just because your house is Indooroopilly doesn't mean shit ;) Moggill Rd moves south west at that point and crosses back through the border putting your street (from the first HOUSE) in Indooroopilly.
Don't argue directions with the ex cabbie bitch :P
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
