You and me both. Maybe we should team up and fark over brisbane :D
Hold them to ransom until we get 11ty cents.
You in ?
Cut off power and water? Sounds almost as fun as the zombie apocalypse. In.
Righty you start stuffing with the power, i'll re-route all the sewage to town hall and turn off the water.
Make sure you get some supplies first...
do you mean montage?
Obviously he wants to perform Romeo and Juliet with a Tokyo Drift theme.
Countdown to shitty Brisbane T - 30mins?
Yeah smarty
pls leave my powah and poo pipes alone though kthanx
Can't promise that. We might have to if we don't get our 11ty cents.
Hasn't it always been shitty ?
A nice touch :D
If your going to screw something up you may as well do it with style :)
wasn't tokyo drift kinda like that anyway?
Fine then... I'll just keep your damn ratchet. :D
I ended up with the NPC twin 1000hp.
i call bs! but feel free to prove me wrong :P
.... on the weekend?
True story, she is a speed mechaninc can do the injector swap on a s14 motoer in 24 minutes (yes we timed her when we were bored) and did her water pump in about the same!
I'm sure we could have too, had we actually started you know, in the morning and not mid afternoon :D
Couldn't go back in the same day anyway, he had to get the exh manifold faced on both sides.
P.S. can get an RB in and out in a few hours, sif need a whole day. SRs are sh*t :D
SRs are heaps easier to do pretty much everything :P
And Hello all, St Patricks day at the Irish club last night was even beteer than the St patricks day parade day on Saturday, awesomeness incarnate
Did you just surface?
I call BS. Lets start with engine mounts... :P
why would you take hem off? Just take them out with the engine?? and in that case they are just one bolt from the bottom, from my fuzzy memory anyway!
You going tonight Jason? Or working? If you're going, wanna drive over together? I gotta give you back your socket and ratchet, and we should limiter bash a tunnel on the way there :P
Hey Isola, If your talking about the Flem 7, becareful of the 4 speed cameras and all the security cameras in there. Don't wanna see you guys loose your lic. cus that would be as gay as aids :D
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
    • Not yet quite as bad as what we've seen a Jim Berry clutch do in an R32 GTR though when it decided to cut a chassis rail in half... Still very very gnarly and a great reason to avoid.
