no, not really. Because the number of times I've actually driven at the speed limit would be in the thousands. The number of times I've driven over the speed limit wouldn't even be in the triple digits. Remember I drove a cab for years, so lots and lots of good boy driving time to stack up against my handful of indiscretions.
If you loved me more, you'd see me more often. Don't blame me for it :)
I cannot base my assumptions on data I have not seen. :P
what is the speed through it anyway? i thought it was 80, thats enough to make some noise! lol
2nd gear limiter all the way. Then at the end if they pull you over for excessive noise blame toyota and hope they recall some more cars.
I'll even put a playing card on the back wheel for that awesome sound :D
I should do that on mine lol.
Page to the other ranga you mean :(. Colin is the ranga.
Oh and the tunnel limit is 80 normally, but they can lower it at will :D
:P I feel special
1. debatable - pommies don't count as people.
2. "LOOK!!! Imports! Set it to 40 AFTER they enter. Let's fuck up their shit"
Pommie/Strayen/Ranga I count as something goddamit!
ok this is how its gonna go .......
smity is gonna ride a pushie with a stack hat covered with zip ties. of course he will be noticed immediately so thats our que to come through the tunnel and amp up the noise so they get distracted and he can make it through, then we all take a different exit and laugh our asses off!
and if not we all make it on the news .....
Look forward to seeing you on the news :down:
the ranga army is gaining strength ......
Wir musen die juden ausrotten!
They're still no threat: They can't go out in the sunlight :)
True, you got us there ..... :P
We shall assemble our forces and attack with the cover of darkness! RED POWA!
I can't hit limiter in 2nd gear and still be doing 80...
*müssen
To be fair it would have been easier with ratchet spanners, but we didn't have any (Remind me to bring mine this weekend Tristan). But still, next time you are under an RB look how easy those suckers are to get at.
Then theres the culprit heater hoses. Piece of p*ss to get to in an RB, smashed up between the engine and firewall for an SR.
amen! ratchet spanners are win!
ps ppl,
the 180 now has custom brake lines
jealous?!
they is the hot!
off to fulcrum and then engineering place now :P
I keep handing everyone the pages by making the last post on each page!! Dammit!
At this rate, we might make 1000 this year...
+1
LOL!
+1
:D I feel special
You are 'special' :D
Git?
Eich die riesh ver reich...
Red Fail
Sure you can: wheelspin
*müssen
umlaut skillz
jealous?!
they is the hot!
pics or GTFO
    • Hi. This is just my curiosity because iam sure the tuner figure something out...but either way i want to ask. The "problem" is that the Nistune ECU (Stagea FW and RB25DET NEO from Stagea) sees many times the speed than the speedo does(he says the speedo show 120 km/h - correct speed and the ECU shows like 510km/h ) I told him that this car/tranny getting speed from rear diff. If iam not mistaken the RB25DET NEO "need" to see tranny speed sensor? (my tranny has the plug for it). So couple of "question" If he connects/wire the speed sensor to the tranny...are the signals gonna intervene and if...what if he disconnects the rear diff one and the speedo stops working? Or the "new" sensor from the tranny "take over" and will not going need the one from diff? As i said i know he figure/get that done...iam just curious to know what are the solutions 🙂
    • Your IACV is set to idle too low. You need to adjust it via the screw Duncan mentioned. From memory it should be 650rpm with the valve electrics unplugged. What is it trying to idle at with the IACV plugged in?
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
