no, not really. Because the number of times I've actually driven at the speed limit would be in the thousands. The number of times I've driven over the speed limit wouldn't even be in the triple digits. Remember I drove a cab for years, so lots and lots of good boy driving time to stack up against my handful of indiscretions.
If you loved me more, you'd see me more often. Don't blame me for it :)
I cannot base my assumptions on data I have not seen. :P
what is the speed through it anyway? i thought it was 80, thats enough to make some noise! lol
2nd gear limiter all the way. Then at the end if they pull you over for excessive noise blame toyota and hope they recall some more cars.
I'll even put a playing card on the back wheel for that awesome sound :D
I should do that on mine lol.
Page to the other ranga you mean :(. Colin is the ranga.
Oh and the tunnel limit is 80 normally, but they can lower it at will :D
:P I feel special
1. debatable - pommies don't count as people.
2. "LOOK!!! Imports! Set it to 40 AFTER they enter. Let's fuck up their shit"
Pommie/Strayen/Ranga I count as something goddamit!
ok this is how its gonna go .......
smity is gonna ride a pushie with a stack hat covered with zip ties. of course he will be noticed immediately so thats our que to come through the tunnel and amp up the noise so they get distracted and he can make it through, then we all take a different exit and laugh our asses off!
and if not we all make it on the news .....
Look forward to seeing you on the news :down:
the ranga army is gaining strength ......
Wir musen die juden ausrotten!
They're still no threat: They can't go out in the sunlight :)
True, you got us there ..... :P
We shall assemble our forces and attack with the cover of darkness! RED POWA!
I can't hit limiter in 2nd gear and still be doing 80...
*müssen
To be fair it would have been easier with ratchet spanners, but we didn't have any (Remind me to bring mine this weekend Tristan). But still, next time you are under an RB look how easy those suckers are to get at.
Then theres the culprit heater hoses. Piece of p*ss to get to in an RB, smashed up between the engine and firewall for an SR.
amen! ratchet spanners are win!
ps ppl,
the 180 now has custom brake lines
jealous?!
they is the hot!
off to fulcrum and then engineering place now :P
I keep handing everyone the pages by making the last post on each page!! Dammit!
At this rate, we might make 1000 this year...
+1
LOL!
+1
:D I feel special
You are 'special' :D
Git?
Eich die riesh ver reich...
Red Fail
Sure you can: wheelspin
*müssen
umlaut skillz
jealous?!
they is the hot!
pics or GTFO
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
    • Does anyone on here know which wire on the GTT triple gauge pod harness is for the oil temp gauge? my sensor works fine but I upgraded the gauges to DEFI advance. And if I can simply piggyback off the oem oil temp wire to the Defi oil temp sensor wire that would make life so much easier.
    • Even face her a wash now that’s it worth more than my house
    • This was what I was invisioning, or Pete cutting a beer can up and hose clamping it around the catch can! Ha ha ha
