SO i wanted to buy a Billionaire boys club or ice cream stuff..
turns out prices go from $80 USD too over $1000 usd thats not even including postage.. fffuuu :down:
but most of the styles i dislike!
Nothing quite like waking up to a gobby.
Very true, well done! Not as good as that for me, but did get the old handy-j (and YES, from someone else, before anyone makes any jokes).... not a BAD way to start the day, that's for sure :huh:
Sorry Dave, but in this thread claims like that MUST be backed up with pics
Quiet you, he was too busy enjoying it.
Either that, or it mustn't have happened :down: hahahahaha
why cant i find a N/a RB20? *sigh* i thought they would be lying around all over the place
We'll just chuck the 25 in it. I should have the cash available after the house warming party :down:
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
