hopefully they all kill each other off.
now - if anyone ever thinks that they've had the world's greatest page claim... I put it to you sir/madam, that only did you suck off a horse... but... I fucking win
Truth.
P.S. Fap
Edited by Smity42
re zombie champion...Vampire wins, Vampires cannot be infected by anything they are effectively immune to all viruses ect, also if the vampire in question is Vlad Von Carstien he could not only hack the zombie to pieces but then re animate it again to join his side as he is able to perform necromancy :D winner!
Yes but ever since twilight... Vampires are gay
Von Cartiens will NEVER be gay, im thinking about a movie where the Von Carstiens destroy the cullens just because they can
Twilight has no vampires in it. Go out in sunlight, don't kill humans, drink animal blood. They aren't vampires. I'd have to go with Andy on the Vampires > Zombies. They can't be turned into Zombies because they are already dead. Vampires are essentially zombies without the mindlass rage/stupid BRRAAINNS mentality.
That is not completely accurate though. The scenario we are discussing is a 1 vs 1 death match. The fact that some humans would be able to kill 1 zombie means it would be a cakewalk for a vampire. Quote from the article link
Vampires are strong, but not invincible. The Zombie Survival Guide estimates that an average human can fend of 8 to 9 zombies. Assuming vampires are at least 10 and at most 50 times stronger than humans, then a single vampire could fight off between 80 to 450 zombies.
Zombies are fine if they are attacking in numbers but 1 vs 1 they are pretty pathetic.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
