wedding night accommodation booked.
have a porsche booked for the next day for a day, so going to enjoy flogging the piss out of a new boxster.
That's no way to talk about your wife to be
Look at this RAVBAT! Go Son!
mangs, scrakin?
Martin and I are going to be the Advan Brothers ;)
Martin - buy the 260. If not, get the RX4. If not, don't buy the corona. That thing totally has gaids :)
Jason - flow chart looks like complicated. Will get to it a bit later.
Colin - find me better offset Advans in 18x9.5 for the same price :P (too late anyway - I'm picking them up later this week. Whenever I can steal the submarine to do so). Also got tyres organised, so should have the rims on the car this weekend :)
pfffttt, complicated pahlease.
Did you go with plan A when you got those rims ?
mangs, scrakin?
Martin and I are going to be the Advan Brothers :blink:
Martin - buy the 260. If not, get the RX4. If not, don't buy the corona. That thing totally has gaids :down:
Colin - find me better offset Advans in 18x9.5 for the same price :P (too late anyway - I'm picking them up later this week. Whenever I can steal the submarine to do so). Also got tyres organised, so should have the rims on the car this weekend :ninja:
advans are pure win
go 17s however :)
17*9 :)
hells yeh you do
that pic backs up all my arguements about how a 32 should look
-no spoiler
-gtr front end
-17s, 9" or wider
however im not sold on the colour
hells yeh you do
-no spoiler
-gtr front end
-17s, 9" or wider
they're 18s in the pic though right? They look like 18s.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
