Here is the flow chart.
Morning peoples
*HEADSPLODE*
Apparently I am dead, but at some point made sweet sweet love to a promiscuous co-ed while barricaded from zombies in the food court KFC and it was totally worth it :)
My friend in the white shirt and I went home with all four
If true, yes indeed you are the winner.
Picsorban.
However, we still haven't determined if Tristan and co fail at the English language, or just fail at life...
Picsorban.
Nothing worth photographing happened.... will work on it this weekend though hahaha
Not understanding this?
^^^ id argue fail at neither...
yeeep
I'm agreeing with you
trust me i have run ravi thru a his pep talk, he is looking calm, focused and completely understands his task at hand
work shall continue, and i would argue, should be completed by the weekend
which means that we will see bewbs sunday night... or unfortunately there will have to be a ban ravbat..
I think this should be on every page
I may even have it as my sig...
How hot was the fifth woman ? The one behind the grassy mole. :)
I mean the one we can't see.
and im trying to say chick B is the hottest - hottest you can see
chick "Z" as i call her, is the hottest - but ravi needs to post up a better pic of her
Quoted just so I can look at it again :D
Thankyou Colin, I appreciate you saying that about me.
Corrected, and thankyou for even putting me above 5 AHAHAHAHA.
She really is smokin hot, she just wasn't in the mood for photos at the time.
Ain't too bad yourself mate ;)
YW Ravbat :)
see i dont kno - i think the girl on ravis right looks the hottest
Number 2 right?
I'd go the one on Ravi's left (Right of Ravi in the pic)
Number 4 right?
marto a simple "+1" or "tristan lets double team her" would have been fine
I would like some eiffel tower love
+1
our right, ravi's left. long brown hair. that chick = win. all the others can be thrown back.
Number 4?
This post is useless without pics.
B omg
QFT.
I stand by my original statement of 2, 4, 1, 3, 5.
sif B
C is teh winnar
dude trust me when i say, the 5th girl you cnat see is the hottest
Chick B looks like she needs a steak or 11ty
I demand pics of chick Z
Me too
She has a nice hand :)
Guys what we're doing is silly. Clearly in order to make an educated decision we require more information in the form of BEWBS! Deliver Ravi otherwise I won't be the little spoon anymore...
Hahahaha well Tristan's been mentoring me so this weekend hopefully we'll have some BEWBBBBBBBS to report in with hahahaha
Having said that, I'm not sure how good T-dawg is with the ladies :)
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
