Guys what we're doing is silly. Clearly in order to make an educated decision we require more information in the form of BEWBS! Deliver Ravi otherwise I won't be the little spoon anymore...
+1
Having said that, I'm not sure how good T-dawg is with the ladies :)
They think he is one of their own...
Hahahaha well Tristan's been mentoring me so this weekend hopefully we'll have some BEWBBBBBBBS to report in with hahahaha
Having said that, I'm not sure how good T-dawg is with the ladies ;)
Who better to coach you on the ladies than the lady boy himself :)
thread needs more epic signatures and a pics of girl Z
Epic signature is epic.
wow i really liek this 32 - wheels sit perfect
It looks a lot like my old 32...except a shitter blue:P Oh and i had far cooler looking brakes :)
I'd go the one on Ravi's left (Right of Ravi in the pic)
Same
which one(s) did you go home with?
My friend in the white shirt and I went home with all four
Its not about the going home its about the nailing the ass out of them when you get there, if this wasnt the case this story and excitement needs to end now because it saddens me
oi i was actually thinking of cropping myself into that pic, changing my face with grumpy - i mean - i doubt you'd even notice, except id have a cheesy smile :)
dont use photoshop use paint, its radder
Same
Andy you're a mad kent
Do it, you skirt!
yeah agreed, drop it for now... Wait til there's something to REALLY write home about. Nice sig hahaha
    • I tried the next one up from 600k ohms which is 60M on my multimeter and all readings came out as 0.00 ohms so right now the most accurate is 600k ohms with only a 0.1 ohms difference between coils. Three coils read 1.4 ohms and the other three read 1.5 ohms.
    • surely that is a control arm, not a sway bar. In any case, visual condition should not be an issue, excessive movement under load (eg with a big pry bar) would be the issue. I can't see 99.999% of pink slip places even looking, let alone trying to test it
    • I attached the image of the only thing I found, nothing to do with ohms in the manual only torque values etc. However, being they are so close to each other I am almost certain they are good. Tomorrow I will test the spark plugs while I am there. and look at the ECU connections.
    • Hi Gents. Do u know what 18rim will fit under R32 GTST with no modification of current setup I have. I have buddy Club P1 17x8 on front and 17x9 rears and they fit well.   Will an 18x9 on 35 off set with 235 tyres up front fit? ON the Rears i can run the rim size n fit 255 or 245? or i got option to get 18x9.5 on 35+ Offset n 265?   CHeers
    • And, when measuring and getting <2 ohms, perhaps chose the next larger range than that, rather than something with a k in it!
