name='Isola' date='28 Mar 2010, 02:22 AM' post='5153241']
there's no keener kind of keen!!
If only there was... it will always be the dream.
Avatar... fern gully
Same thing ? :O
For Tristan:
How to properly repair rust, something which whoever did the dodgy-ass job on your 180 should take note of (Note: not the job Dave did last weekend, that shit is legit. I am talking about whoever did the original abortion). Bought to you by Garage 31.
Step 1: Actually remove all the rust.
Step 2: Apply paint. For best results, this should be the same colour as the original paint and done by someone who knows what they are doing. But at the very least paint it with something, to prevent MORE rust.
Step 3: Profit.
Result:
Big thanks to Dan for coming and doing the major bits of painting last night!
After lunch, all the panels will be going back on. Then its a trip to the paint shop tomorrow to try and sort out the dodgy ones...
Edited by Smity42
YOU'RE a dodgy one....
For Tristan:
agreed - grinding back, and exposing the rust - and not treating it at all is a piss weak effort, much can be said about such questionable workmanship
however,
another thought for rust (not removal, but maybe containing?) is when u have a small amount of rust from where the paint cracked when u rolled your guards - simply cover it with some clear nail polish - and it will contain it, until u are ready to remove it and fix it correctly (usually done when car is re-sprayed)
i am going to do this once it stops raining and it is dry ;)
the job you've done in the pics looks quality mang!
ps, also ordered some epic headlights - hopefully ill actaully be able to see more than 10metres in front of me hahahha
That's what she said
however,
Yep, I've been busy fixing all the rust from guard rolling too. I sand the rust off, and then hit it with touch up paint.
But good call on the nail polish, that should stop it rusting at all if you apply it as soon as the paint starts to crack.
im going to dodge the f**k out of you
went zorbing today. was awesome fun. Started the gtr as well. want to drive so bad lol. Ill grab some pics of the new ESSSS AARRRR now.
Speaking of pics. Here is what Dan aka The Legend - did for me today:
Right:
Left:
Front:
Rear:
And not only that. He also got my A/C working!!!! ;)
I drove home with the windows up!!
Thanks heaps Dan! Awesome work :blush:
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
