Just remember that when I take you to dinner, I expect you to put out
I want the 1900 number...
I've been known to open my legs with ease.
but a 1900 number wouldn't be a local call cost :down:
I'm So Ronery
So ronery
So ronery and sadry arone
There's no one
Just me onry
Sitting on my rittle throne
I work rearry hard and make up great prans
But nobody ristens, no one understands
Seems like no one takes me serirousry
And so I'm ronery
A rittle ronery
Poor rittle me
There's nobody
I can rerate to
Feel rike a bird in a cage
It's kinda sihry
But not rearry
Because it's fihring my body with rage
I'm the smartest most crever most physicarry fit
But nobody else seems to rearize it
When I change the world maybe they'll notice me
But until then I'rr just be ronery
Rittle ronery, poor rittle me
I'm so ronery
some 16 year old thought she'd be 'different' and now it's a plague.
Ahh that explains it. So far I have only seen it from 16yo girls on faceparty and Tristan (who is a pretty good approximation of a 16yo girl).
The zombie apocalypse will take care of it :down:
Can't wait *sharpens machette*
on the lock nut or the tie rod end itself?
Tried WD40?
EDIT: Or the castle nut?
on the actual rod, the other stuff came off fine.
Off to a job interview now!
Dah dana dah!
*puts on cape*
whhooosh!
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
