Going to EFI would even make baby Jesus cry
*shrug* they are the best at what they do, it took a long time for me to find some one competent in diagnostics
oh and VGs are ballz :)
the fact that these two comments are backwards from the truth, prove you're on drugs ;)
the fact that these two comments are backwards from the truth, prove you're on drugs :)
the oscilloscope proves that all I am saying is the truth!
cr4p. What was I meant to get again?
I'll have to get dan's too, since hes gone out west
How many GB are required for your bit?
5.5ish gig from memory
you were supposed to get S1 and Dan S2
Just got an invite to a group on facebook called Save the Regent Cinema or some bullshit like that. GODDAMN HIPPIES f**k OFF!
I got that too. *ignore*
I did save the mad picture of Queen street though :cool:
Hippies standards for what qualifies has a historic/iconic building are getting lower and lower. The real regent theatre was torn down in the 70s to make way for that shitty cinema so congrats to them they're only 40 years too late. Our proposal keeps the exterior, entry and foyer which are all pretty cool but I don't see the attraction of the shitty cinemas inside. Does anybody go to them?
no
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
    • Does anyone on here know which wire on the GTT triple gauge pod harness is for the oil temp gauge? my sensor works fine but I upgraded the gauges to DEFI advance. And if I can simply piggyback off the oem oil temp wire to the Defi oil temp sensor wire that would make life so much easier.
    • Even face her a wash now that’s it worth more than my house
    • This was what I was invisioning, or Pete cutting a beer can up and hose clamping it around the catch can! Ha ha ha
