What
The
F_ck
Woman set on fire during surgery
Happy John :D
Fire, solves everything.
fix it... making brain hurt
Fixed:
I say, old chaps, I do appear to be suffering some minor homosexual tendencies when posting on this fine forum. My browser of choice is the fabled Internet Explorer but alas, when I submit a post it appears not once, but twice! It's just not cricket.
Edited by Smity42
Stoopid pintaras...
Got home from work yesterday and noticed my brake lights were stuck on :D. Don't know when it started, but presumably it was yesterday sometime or my battery would have been flat yesterday morning.
Fortunately, all the inconsiderate, uneducated, and generally incompetent drivers of Brisbane somehow managed to avoid running up my a*se despite having no indication of when I was stopping :bigthumb:. Good job, team!
So I got out my multimeter ready for some HK electrical diagnosis. After doing some Houdini tricks I managed to unplug the switch that triggers off the brake pedal. Lights go out. Then I used a bit of wire to bridge the contacts, lights come back on. That settles it then: the switch is faulty. Out I go to the ute, perform some even more impressive Houdini tricks (since it is parked beside the house and you can’t open the driver’s door) and manage to get the switch out of it. Back to the coupe, but as I go to remove the switch from it, I notice that there is a hole in the brake pedal where it should be triggering the switch. So basically, the pedal is not actually pressing on the switch. Well that explains it, there’s obviously meant to be something in that hole. I found half a dozen pieces of rubber in the foot well that almost re-assemble to form a rubber stopper. That would be it! BACK to the ute now, more Houdini tricks to remove that rubber stopper this time, then again to put it into the coupe. Fixed!
Profit.
Im here ... Does that count or have I been kicked out for my lack of presence at the BnR meets :)
No, but if you don't start turning up again soon you will be! :D
Good morning!
mang.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
