I'll have to go check out the honky shops in the valley some time and see if I can track them down.
there is a shop in the sunnybank mall that has them for $90
Happy Eastering mangs.
:P
I think we should have this system instead of the speed cameras we have here. I think the results would be a lot better and the speeding fines would be cut in half.
Denmark speed reducing system. NSFW
:P
Video doesn't work for me. But I can picture it. It wouldn't work here. People are too stupid. They'd speed up to get from speed babe to speed babe, and slam on the brakes at each one and do a huge line lock while lighting up winnie blues and chugging a VB screaming out "scarnon beudaful? showusyerpinkbits!" then skidding off, lolling to themselves and congratulating each other on how incredibly funny they are, and did their passenger happen to see that rad skid that they pulled in their hektik holden.
Plus... the speed "babes" used here would probably just be recruited from the local caravan parks. Orange spray tan, sunken cheeks, needle still hanging out of the arm... the kind that look like they'd be sticky to touch...
In
:P
whats crackin' mangs? (other than zombie sechs)
Looking at the denmark speed reduction campaign... Interesting.
Working and watching a doco on coral.
My day is so complete.
nothing much. sitting around doing considerably close to bugger all.
I prefer doing Sweet F*ck All instead. :P
+1. It's so good to just have all this time off... went and got a new bed today though since I sold my epic jap style one when I moved in with my (now) ex. Regretted selling it ever since.
In other news, been seeing one of the girls..... things are going verrrrry well
Scracking mangs. Lights on the dirty one work motherf**kers :down: Just need to sort out the wipers and that's all the electrical bullshit done with. Started degreasing all the S13 gear ready to put in tomorrow if I can feel bothered.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
