Morning mangs. Didn't get much done on the 31 on the weekend :D Got all the lights working and I degreased all the S13 gear ready to go on but I cbf putting it all on. The waterpump broke on the tractor so I helped dad fixing that a bit and did some uni work. Not as productive as I would of liked but not terrible either way.
Dan you dog why didn't you tell me you were playing futsal! Where's my invite?
@dan - i missed you broooooooooo
news.
i have news.
josh is my new idol - as i found out last night that the kid ran his daily lexus with just 20mm ride hight, daily.
<3
news.
i have news.
<3
did he also tell you that he painted it with undercoat from silly sollies and it looked like an abo car? :D
another good use will be trap and skeet shooting.
quiet day in here?
Colin, there will be more seasons of futsul, and im sure i will have people drop out on me again
    • I tried the next one up from 600k ohms which is 60M on my multimeter and all readings came out as 0.00 ohms so right now the most accurate is 600k ohms with only a 0.1 ohms difference between coils. Three coils read 1.4 ohms and the other three read 1.5 ohms.
    • surely that is a control arm, not a sway bar. In any case, visual condition should not be an issue, excessive movement under load (eg with a big pry bar) would be the issue. I can't see 99.999% of pink slip places even looking, let alone trying to test it
    • I attached the image of the only thing I found, nothing to do with ohms in the manual only torque values etc. However, being they are so close to each other I am almost certain they are good. Tomorrow I will test the spark plugs while I am there. and look at the ECU connections.
    • Hi Gents. Do u know what 18rim will fit under R32 GTST with no modification of current setup I have. I have buddy Club P1 17x8 on front and 17x9 rears and they fit well.   Will an 18x9 on 35 off set with 235 tyres up front fit? ON the Rears i can run the rim size n fit 255 or 245? or i got option to get 18x9.5 on 35+ Offset n 265?   CHeers
    • And, when measuring and getting <2 ohms, perhaps chose the next larger range than that, rather than something with a k in it!
