My dear son of rajab. If ever there was a candidate for an axe to the gooch this is the one.
from what I can gather he lives up the coast... I think I need to find details so we can go beat him up
God dammit... where is everyone? I feel like i have Martin's disease :)
Sorry mang, researching fun stuff like seam welding and roll cages
also the net here has aids today :D keeps dropping out
Did you guys miss me at all??
Nope :D
Did you guys miss me at all?? I'm on my way to the airport about to get on a plane back to brizzzzzzzz
sup?!
Scrackin mang, How was melbourne? Did you go see our favourite black man?
Nope :)
Would like to know more about seam welding.
we fapped over your facebook to keep ourselves busy <3
Pretty much :D
for project alfa?
You know it
+1 <3
Summary of what I have learned so far:
  • Cage first, then seam weld (cage helps prevent heat warping the metal)
  • Better if it can be on a chassis rig, but failing that, weight should be on the stock suspension points
  • Weld inch on, inch off (solid welding bad)
  • Try to move around a lot when doing it to stop one area copping a lot of heat at once
  • Only do strut tower to strut tower, no point going further forward or back and can in fact make accident damage worse
have not seened. up to episode 8 so far.
can't find episode 16 for download either. it's annoying the crap out of me. got 15, 17 & 18 with no 16 ;)
I'll bring it for you
What do you want to know???
How much? Whats it come with? Where is it? Pics/etc?
    • Hell, I'm sufficiently wary of the ZSS suspension arms, let alone something like a hub.
    • Got it back home and got started pulling the hub off and diagnose the issue. Axle was stuck after removing the 36mm nut so i used a 3 jaw puller to try and push it out and... eH5FXvJ8.mp4   spend the next few hours trying to remove the axle from the remaining hub as it was very much jammed in there when the spindle sheared off. resulting damage as below R53AIy6 - Imgur.mp4   Looks like the was already a stress fracturing in the spindle as can be seen with the darker cracked section My working theory is maybe when the pinion gear exploded last year the shock put through the hub was the initial crack. Then a few events later it finally let go. Just lucky it happened where it did and not 190km/h on the next sweeper or into the hairpin The bearing/hub assembly went in in 2019 and were non-genuine "ZSS" assemblies and no nails were harmed in the process. #BreakHubsNotNails
    • Thanks mate, couldn't find in VIC, ended up ordering one from NSW, getting rwc to get new plates and registration done.
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
