Cool! We can make it a mixed team, I dont propose we make an official team, just a bunch of people turn up of a sunday arvo in a park somwhere and play, at school we would do this all the time we would play league rules and use peoples shoes to mark the field lol
We could play red rover too
Preliminary Rollcage Ideas (courtesy of a picture off the internet and MSPAINT)
Green bits will be included if they are affordable and allowed under CAMS (nothing about them in sched. J of the cams manual though)
Purple bit will only be included if its cheap and the cage builder tells me its worthwhile.
Not sure which way to go with side intrusion yet. If double, apparently the old school X is not strong at the join, it needs to be gussetted or use two bent pipes welded together instead.
If single, I think I prefer it running right back to the harness bar as it doesn't create a bend point halfway up the main loop then...
What about the ladder style side instrusions? And the purple bit is the other bar to make the roof cross/X right? Would of thought that would be pretty standard for a cage builder to deal with ie not that expensive? Stuff penetrating the firewall is generally more expensive and difficult from what I've seen/read about on the internet.
I would prefer the two bent bars for the side intrusion but it's not like it's door to door racing so you're not likely to have anyone come crashing through your drivers door.
Squares are bad. Triangles :ninja:
Yeah, but I think the second part of the "X" is redundant here. Leaving it out will save weight and probably cost. Unless the engineer tells me its important its gone.
Yeah, but it also gives the most benefits for chassis rigidity. If its allowed by cams and not stupidly expensive, I'd like to include it.
Yeah I havend decided yet... the two bent bars would be best but the single bar would be lighter and probably enough. Unless I decide to use it for rallying and then I'd want the double bars.
I'm also tossing up wether to put a harness bar on the main loop as well so I don't have to run them right to the back...
wow there is a blast from the past
that got banned at out primary school due to injuries lol
Or force em back with the footy
great days... great days
Triangles obv > squares agree was just throwing it up as another option.
Most of the cages I've seen either have an X or a V in the roof. If engineers reckon it isn't needed I'd leave it out but I'd always want that extra protection if a roll over happens
Definitely better for rigidity but I only ever see it on the more serious cars which makes me think it will probably be prohibitively expensive.
Have a look at how Risking on here does his cages. He has the harness bar in the main hoop aswell I'd rock it like that if you can
Yeah found this thread, it's given me a few ideas for changes.
I might go with the V roof, it looks pretty strong (triangles) and not much more weight than the single bar
so who's coming tonight?
Martin & Dan will be westward bound for project alfa and thus be late.
I don't want to be just sitting there with my dick in my hand for 2 hours... so who else is coming?
league rules wins = epic grubbers and 5th tackle plays
Yeah football with out kicking is a bit shit, The only real problem you get is knock ons, leads to some interesting convos, so perhaps league rules with one touch rule, that being if the ball hits the ground its a turn over.
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
