Yeah I could do that, but at the same time this car will keep going forever after a bit of TLC, so I might as well do it right the first time.
That's so unlike me, I'm always about the quick fix, just get it good enough.... what the f**k's going on!!
too much laser love
Edited by Smity42
Mangs. Just checking in from an Irish pub with free wi fi in Dubrovnik.
Cars of interest spotted in Europe so far:
one 180sx in Rome, but I think it may have been it's American cousin the 240sx.
And one four door 35 with infinity badges.
And lots of vw's
not when it comes to Fords ;)
Fords are awesome ;)
And lots of vw's
needs more beer :)
needs more beer :)
I am working on it. Beers here are $2 for pints.
Almost as good as hong kong, $5 for a four pack, sold at 7eleven and petrol stations
And lots of vw's
having fun bigfella?
Having fun, but as for hot beer wenches, can't quite give them the attention they deserve as my wife is with me at almost all times.
But as a general rule, Croatia seems to be filled with stunners.
Not like Serbia.....
lol - I knew something had been missing on this forum for a while. The good ol' serbia bashing :)
Dan_B:
I got this message from a dude on Boostcruising about a VG30DETT:
Hey mate i found out about the motor for you, it comes with everthing, turbo's ect. except no wiring harnes. It has dropped pressuse from one of the cyclinders but he dosen't know which one???? Apart from that he said it runs great. He said the price is $600 Neg.
What do you think?
Edited by Isola
Agree on the no. f**k the VG. Oh and as I said to John last night. f**k YOU GUYS. Burn Notice is awesome and I ended up going to bed at 2am last night because I couldnt stop watching them. Now I've got to stay in work and do my uni assignment because I know if I go home I'll never get anything done lol.
But Dan might know how to work some VG magic :blink:
Well, I question old mate's diagnostic technique.
He says:
now by 'dropped pressure' I would assume that means no compression? But how he tells it has no compression in 1 cylinder without testing them I don't know, and if he'd tested them he'd know which one it is. If its actually got no compression on 1 cylinder, forget it, its f**ked.
IF he actually means "not firing" on 1 cylinder then it could be something simple causing no fuel or spark to that cylinder, in which case it would probably be a very easy fix.
I would suggest, if you have any intention on buying it, do a compression test on it first and if the cylinders aren't all in spec and fairly even, then stay far FAR away, it's not worth the hassle.
If you can get the VG for like $400 I'd say go for it, if a cylinder is f**ked rebuild it yourself :D
The laser's now rolling on some sweet nolathane bushes in the front ;) oh yeahhhh
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
