Im listening
I hate it when you put words in my mouth Nismoh
I see youve played RAPE as well.
It's not rape it's suprise sex :thumbsup:
Shh, Thristan will get upset.
Is everyone still doing "winter" ice cream?
Thristan will understand :thumbsup:
We're there every week you should come and play cars with us Josh
Morning Mangs
Morning
Also a good use of duct tape
The jailbait is there regardless of temperature...
I wanted to play something else with Josh...
I'll come this week if Thristan is still driving me
Sick
Can I wear a scarf if I come?
I'd be disappointed if you didn't accessorise Josh
cheaper option: Duct tape a hose to the trumpet(s)
I had thought about it TBH... will it recirculate well enough to not blow shit up though? or well enough to not cause random stalls making me look like an L or P plater?
Definitely.
If your hose is big enough (that's what she said)
yeah, but does it vent as much through the 'trumpet' as it would through a recirc hose/pipe? Or does it only vent a portion of what a recirc BOV would vent back into the pipe work, and send the rest back to the turbo? I don't really know how atmo valves work to be honest...
afaik, they work exactly the same, just an atmo one dumps the air to atmosphere (usually, but not always, via a trumpet of some sort) while a recirc one runs a hose to dump the air back into the intake.
Guess there's only one way to find out if it'll work then. :happy:
Bingo. We recently had to turn Annas atmo bov to plumbed back and all it required was the right size hydraulic hose (bendy and built to take pressure) and some hose clamps. We tried other hose but it kept getting holes blown in it
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
    • Unfortunately the cavaet to that is that while any scan tool should be able to read the code, the workshop will need a consult plug to OBD socket adapter. You don't have a location on your profile, where are you based?
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
