hey :P
Damn it! You're always going to the German club when I've got something else on!! But, to be fair, I went out delicious Austrian food last night :P
German club on game day is fail :thumbsup:
Mana bar is fail :blink:
Roof of Alfa Brisbane is awesome :thumbsup:
Yeah what happened to you! I get a text from you asking me where Tarlae is, and after I reply, I got no more communication! Dog!
Sounds fun. Was it a good view?
Would've been better if Tarlae was there? :P
Edited by mosquitocoils
Ooooooo Tim is pretty keen :thumbsup:
She is good eye candy :thumbsup:
For the record, bikini parade next weekend at Planet that a couple of the girls are in. Martin you are coming.
Oh you must have missed the part I put in invisible text. Hang on I'll see if I can quote it:
Anyone else is also welcome, except Jason.
Carnts. My little brothers bday next weekend otherwise I'd be inskies...
Not really :P
so we have a gay cowboy and the XXXX man
lol
Sorry mangski, my phone went flat :(
Would've been better if Tarlae was there? :blink:
Definitely
Spotted Martin, i got wet,
nice
Who the hell is Tim?
he is legend
You don't know Tim ? :thumbsup:
He is a sexy beast :thumbsup:
truth.
    • Sorry I didn’t explain myself properly, by free revving I meant if I just floor it, it gets to 7kish and will start to break up/not hit limiter properly, off boost I’ve driven the car until near on empty. I have a fuel pressure gauge mounted in the engine bay, holds fuel pressure consistently full tank or half tank even when revving, and no the pump sound doesn't change. all the fuel lines inside the tank are fairly new but will look into it, could that also be an issue with the lines outside the tank ?
    • Yeah maybe I got a bad batch that only lasted 6 years. Or conversely maybe I got a good batch that managed to last 6 years.    Either way I have sourced a set of OEM hub/bearing assemblies  so I keep hearing! Even from life long mechanics. Apparently this failure is unheard of…
    • I am trying to understand how that even happened to the hub... wtf
    • Hell, I'm sufficiently wary of the ZSS suspension arms, let alone something like a hub.
    • Got it back home and got started pulling the hub off and diagnose the issue. Axle was stuck after removing the 36mm nut so i used a 3 jaw puller to try and push it out and... eH5FXvJ8.mp4   spend the next few hours trying to remove the axle from the remaining hub as it was very much jammed in there when the spindle sheared off. resulting damage as below R53AIy6 - Imgur.mp4   Looks like the was already a stress fracturing in the spindle as can be seen with the darker cracked section My working theory is maybe when the pinion gear exploded last year the shock put through the hub was the initial crack. Then a few events later it finally let go. Just lucky it happened where it did and not 190km/h on the next sweeper or into the hairpin The bearing/hub assembly went in in 2019 and were non-genuine "ZSS" assemblies and no nails were harmed in the process. #BreakHubsNotNails
