oh, and will seam weld from the a pillars to all the front suspension mount points. Theres just no practical way to get enough cage bars through there :3some:
Actually it looks like it may be possibly, by going inside the front guards (which are welded on :)). I might look at how to get those suckers off...
Whats there now?
Are you happy with the tune you got from STZ mang? They are a haltech premium rep or something... (gonna run a PS2000 on the alfa)
there is nothing there - its 100% bare.. hence why i asked
f**k moving all those cars - would have taken ages, would have been a fun night however lol
mate STZ were amazing, car runs so sexy - marty and mic said if there are any dramas just pop in and they'll have a look
defs recommend them bro!
their s13 runs a 60.2 on QR Sprint track - go figure, that thing has the haltech in it (and an SR :3some:)
cant remember what turbo/power figure, but its definitely a very "tame" set up (not like high-octane racing for example)
give them a buzz fo-sho
I say dan buys it and sets up a workshop there :3some:
their s13 runs a 60.2 on QR Sprint track - go figure, that thing has the haltech in it (and an SR :))
Cool as, they are about 2 minutes from my work :down:
...Will be a while till I need a tuner though ;), just doing my research...
Cool as, they are about 2 minutes from my work ;)
...Will be a while till I need a tuner though :) , just doing my research...
dude lets buy it - hoists win!
but yes STZ ftw! should go down and chat to them, i was there for ages just chilling - great guys
I say we all chip in and make it an Apocalypse fortress :3some:
Keen for apocalypse fortress/ somewhere with a hoist. but John needs a job first :)
Martin i can chase down the original workshop manuals for the GTV.
Phantom has relocated over near moss street from memory, i wanted to take the RX7........
If someone wants to front the cash i'll setup a workshop there and mini skid track.
Also, concrete carparks in the wet are too easy
I have them on that disc. They are sh*thouse :thumbsup:
I did find the bit for adjusting suspension though. Height, Camber, Castor, Toe all adjustable on the front from factory :(. Looks like nothing adjustable on the rear :)
Build your own damn fort then.
Fine maybe I will...
Workshop+skid track = win.
Morning Mangs
Epic fog is epic :thumbsup:
Morning mang no fog here but it's pretty quiet on the way to work these days.
Morning to you fine gents
The fog's actually gotten worse since 6am...... go figure, usually it works the other way
Night all.
Is it just me or are those roll over ads at the top a pain in the rectal area? :):thumbsup:
I have them on that disc. They are sh*thouse :(
I did find the bit for adjusting suspension though. Height, Camber, Castor, Toe all adjustable on the front from factory ;) . Looks like nothing adjustable on the rear :D
That's awesome. How much adjustability do you have though?
Could be that deadly fog that turns people inside out. I here it has been getting around again.
Night all.
So true. But they have to make money somehow.
    • Sorry I didn’t explain myself properly, by free revving I meant if I just floor it, it gets to 7kish and will start to break up/not hit limiter properly, off boost I’ve driven the car until near on empty. I have a fuel pressure gauge mounted in the engine bay, holds fuel pressure consistently full tank or half tank even when revving, and no the pump sound doesn't change. all the fuel lines inside the tank are fairly new but will look into it, could that also be an issue with the lines outside the tank ?
    • Yeah maybe I got a bad batch that only lasted 6 years. Or conversely maybe I got a good batch that managed to last 6 years.    Either way I have sourced a set of OEM hub/bearing assemblies  so I keep hearing! Even from life long mechanics. Apparently this failure is unheard of…
    • I am trying to understand how that even happened to the hub... wtf
    • Hell, I'm sufficiently wary of the ZSS suspension arms, let alone something like a hub.
    • Got it back home and got started pulling the hub off and diagnose the issue. Axle was stuck after removing the 36mm nut so i used a 3 jaw puller to try and push it out and... eH5FXvJ8.mp4   spend the next few hours trying to remove the axle from the remaining hub as it was very much jammed in there when the spindle sheared off. resulting damage as below R53AIy6 - Imgur.mp4   Looks like the was already a stress fracturing in the spindle as can be seen with the darker cracked section My working theory is maybe when the pinion gear exploded last year the shock put through the hub was the initial crack. Then a few events later it finally let go. Just lucky it happened where it did and not 190km/h on the next sweeper or into the hairpin The bearing/hub assembly went in in 2019 and were non-genuine "ZSS" assemblies and no nails were harmed in the process. #BreakHubsNotNails
