i do only have a six pack of lowenbrau.
speaking of german beer.... Hi andy!
Nice.
I figure that since I was asked a stupid question I should also be able to ask one. The question I was asked was :
I am watching pacific. I am watching part VIII. I was asked if I had seen the V series. I said no that sci-fi show didnt really interest me. To which the reply was pacific isn't about sci fi, haven't you seen V3 and V4. ( VIII, VIV ). :ermm:
So my stupid question is this:
What's the difference between a GTSR and a GTR ?
Nice.
I am watching pacific. I am watching part VIII. I was asked if I had seen the V series. I said no that sci-fi show didnt really interest me. To which the reply was pacific isn't about sci fi, haven't you seen V3 and V4. ( VIII, VIV ). :D
Whoever asked you that is an idiot.
gtsr is a HR31
31 FTW
thanks
That's what she said
Good evening! Enjoy that glorious Teutonic drop :D
Evening Squire
My brain hurts from that
sounds like someones number plate........
my brain is working overtime, looks like i'll be drifting by the end of the year, motivation is high
Morning Mangs,
Congrats Martin on the cricket win :D Had an epic weekend at home where I did nothing that I set out to do but still kept busy lol.
Friday I got home wanting to put my sexy new wiper motor on the car but the battery was dead. Attempted to jump start it but it was really really dead so battery went on charge. Ended up chopping wood and building an epic fire on the patio and chilled out with dad drinking some homebrew.
Saturday the battery had charged up a bit so I threw it back in and the car started fine. Tested martins wiper motor no dice. So I went back to step one and checked my fuses again. Swear to god the shed is infested with fuse stealing gnomes or some shit. Turns out Terri/Mum borrowed my fuses for their car/s and just hadn't bothered to tell me. Whacked new fuses in and wipers are all good apart from I put the motor back on 180 degrees out lol.
Painted and cleaned everything and it's all back on now. Some small things left to do: need indicator holders for the front bar, new passenger side tail light, check brakes for rwc. The peddle nearly goes all the way to the floor hopefully it just needs to brake fluid or something lol.
Saturday night went out for dinner with family for Terri n Lees birthdays. Had epic steak and chips with salt and pepper calamari at Canungra pub and then Lee couldn't finish his steak so I got to eat that too. Couple of Beers and then home for ice cream cake. I was pretty much dead after that.
Sunday woke up late and came back to the coast with Mum n Dad to find Terris birthday present. Overall a good weekend but I got about 3% of the uni assignment I meant to do finished. It's not due in till Monday next week though so I'm all good...I think.
Epic post. tl;dr
Morning Mangs,
Epic post. tl;dr
tl;dr
Sounds like a good weekend though.
Tell Terri happy birthday, and I have a big hard present for her whenever she'd like to collect.
P.S. Morning mangs
tl;dr
P.S. Morning mangs
tl;dr ? wut ?
Its always only one step away from Terri isn't it :D
Morning all. Get's my turbo today :D
+1
+1
P.S. Morning mangs
+1
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
