Yep I have the manwell for it. I downloaded it from the website. I went to the off setting and it didn't seem to do anything. It was still giving me infinity boost.
F*ck, that's not good :ermm:.
Bring the manwell tonight, saves me having to print it.
Lol @ NASA
Voyager 2: *Gibberish*
NASA dude 1: Hmmm, voyager 2 seems to be broken
NASA dude 2: Have you tried turning it off and on again?
NASA dude 1: Naah, we'd better figure out whats going on first
several days later...
NASA dude 1: Yeah I figured it out, theres a bit-flipped in memory
NASA dude 2: OK, how do we fix that then?
NASA dude 1: Lets try turning it off and on again...
ATTN: Phil, Misohorny, John, Dan
Work out a day that works for everyone to fix Jasons AVCR and do Miso's brakes. Dan will need his brake bleeder. I can't do it this weekend though.
I am easy. Just let me know and i shall be there. Can work it out tonight at baskins. No longer jet lagged, so won't sleep through it. :ermm:
Sounds expensive. So whats doing mangs? I'm typing meeting minutes :D
Trying to clean up scanned alfa wiring diagrams to print. HOPEFULLY they are the right ones :S
Cool, sounds like it will be a good turn out tonight. Thristian, you coming?
Sounds expensive. So whats doing mangs? I'm typing meeting minutes :(
Very expensive. You can only import them.
I am easy. Just let me know and i shall be there. Can work it out tonight at baskins. No longer jet lagged, so won't sleep through it. :P
Anytime is good for me ( if i can afford to drive there :D ) I'm on day shift this week and next and have this weekend and next one off. :ermm:
Anytime is good for me ( if i can afford to drive there ;) ) I'm on day shift this week and next and have this weekend and next one off. :down:
I think tonight we will just bypass the AVCR and pipe the wastegate actuator directly to a boost source. This should put you back to stock boost (stock LOW boost probably) which will get you by (and hopefully fix your fuel economy) untill we can sort it out. Hopefully next weekend will work for everyone.
If it still boosts it's t*ts off, or you still get bad fuel economy, then you have other problems.
I'm not 100% sure how the AVCR can be ruining your fuel economy so much, if anything I would have thought it would make it better as you'd be trying to drive off boost all the time...
Edited by Smity42
+1
o2 sensor? when was that last replaced?
+1
I've only had shitty fuel economy since the avcr. But it is getting worse and worse. How much is a o2 sensor ?
Jason... did you let you car hang out with mine again? I started her up this morning and she was all lumpy and shaking and carrying on, and drives like a bucket of shit :down:
Just letting it cool down now so I can see if I can work out wtf is going on with it ;)
like $100ish i think man
i have a spare good one you could try - if they fit (its an sr one)? idk if they do
was the avcr new? who installed the avcr? i'd give them a bell maybe they f**ked up? (or was it you that fitted it :down:) jks jks
    • Hi GTSBoy, Excuse my ignorance but what does a "Bad" Knee point mean ?
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
