Jason... did you let you car hang out with mine again? I started her up this morning and she was all lumpy and shaking and carrying on, and drives like a bucket of shit :down:
Just letting it cool down now so I can see if I can work out wtf is going on with it ;)
maybe the zinganator has run out of zing ?
Check that none of your dodgy macguyver hose connections are leaking
They all seem fine, car is boosting fine too, doesn't appear to be a leak. No one on Abottsford Road likes me very much after my test though :down:
Hahahaahahhahaha no one on Abbottsford rd likes me very much anyway :down:
I'll probs be over at basksins around 10 tonight? Too late?
Hahahaahahhahaha no one on Abbottsford rd likes me very much anyway ;)
The ice cream will be all melted then :down:
Bored. Finished playing with wiring diagrams.
@Ravi: We're generally gone by then bro, colon has transportation issues and I need sleep :down:
You can try your luck though, some people might hang around if there's a fair turnup
I think i just died from boredom.
Plus side work is finally going to put me through a Associate Degree in Civil Engineering
Yeah ravbat, probs a bit late. Colin has to "run ranga, run ranga, run, run, run" to make his train, which usually means I leave at the same time... being his lift and all :down:
Car is fixed. Was the hose going onto the BOV. I ditched the zip tie and went for some grip tape instead. Bit more air tight.
Now no one likes me in any suburb from Aspley to Mitchelton. Including the police doing 40 up a hill who honked at me as I changed lanes and went past them at 60. They didn't like me changing gears next to them... must have been the BOV ;)
Awesome. Good to hear it was nothing major. Hope we can sort Jason Phil's out as easily.
Now no one likes me in any suburb from Aspley to Mitchelton. Including the police doing 40 up a hill who honked at me as I changed lanes and went past them at 60. They didn't like me changing gears next to them... must have been the BOV :down:
lol
Isn't that like a 2 year full time course? :down:
Yep. Four years part time. Fun fun fun
I have full faith in you Tim / Steve.
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
