morning mangs
+1
Still trying to find where to turn this avcr off. Can you extend the cabling for me tim ? Get my custom gauges holdery thingos at the end of the week
Its on page 18 of the manwell. Basically go to the menu, press down to go to "Setting", then press the left key so it says "Setting OFF". Thats how I read it anyway.
If you want to drop round this arvo I can have a quick look, I'll be changing my spark plugs though and need to get it done so I can drive to work tomorrow. Should be home by 4:30.
Can you extend the cabling for me tim?
Extend the cabling for the AVCR? I guess so, depends how dodgy you want it :)
Winrar!
    • 21 is explicitly the coils detected as the issue. Is it guaranteed the actual issue? No. Just the ECU thinks it is. When you say rattling, describe it better, get an audio clip as best you can if possible.
    • Yea got me coppers. Bad news is I just put them in and the car still has the light and shakes. I also noticed I hear like rattling coming from the exhaust piping right under me. Does 21 also have a possibility of being O2 sensors?   So, coil packs are good, the harness is good, the MAF is working, and obviously the spark plugs just replaced and working.
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
    • @Rusty NutshI mate. Do you have a pinout diagram for the na neo auto ecu?
    • Yeah thats the plan now. 🤞
