chillin
attn Miso: Are you replacing all your brakes mang or just the fronts? What are you doing with the old ones?
Just the fronts at the moment. Don't have any bigger calipers/rotors for the back yet.
Was thinking of selling the old set. You looking for some brakes for project alfa?
I am sure we can work something out in exchange for your assistance to fit the upgraded brakes, and maybe a upper thigh deep tissue massage
Yeah I'm thinking I might try and fit some 32 brakes to the alfa. Should stop it on a dime.
Sounds like fun :D
Sounds like fun :ermm:
Just let me know when you got time.
When we get them off, you can just keep them.
You sir, are an extremely generous bosni-serbo-croat!
I shall have to at least buy you a carton of *insert preferred beverage here*
On a similar awesome note, I just found the old rears off my car, so that will make a nice semi-matching set, assuming I can find suitable rotors for the rear....
As to time, yeah well that's the issue...
Sat morning I think I'm out, Saturday arvo is a possibility, pending what everyone else is doing.
Sunday I'm probably out - although if that's the time that suits everyone I think I can make it work.
Next weekend is good, but Dan will be away, and his expertise will be useful when doing brakes. We could try to tackle them without him but? Le mans 24 hour is on too, always fun to have something to watch while mechanicalising
Thoughts?
Jason, what still needs doing on your car? You got those boost fittings sorted yet?
Thoughts?
No probs, next sat arvo is free. Probably suits me best, as there is no footy in Bris for me to go and watch, and have no games on.
The weekend after is ok, but I am on call for work, so might have to spend a bit of time on the phone.
We can work out a carton of something, and you can assist me in drinking it.
Thoughts?
Scarnon kuntz
Car is currently burning more oil then fuel. Awesome.
Scarnon kuntz
That's excellent news, especially since the latest bp oil leak in the gulf of mexico. little baby seals are thanking you now for ridding them of excess oil.
:ermm:
One of the many services myself and my car provide.
I should get a medal for it
That sucks dude... any idea why?
Also does anyone have a rear set of shocks for a 32 GTS-T? Stock or aftermarket...
Tim can field that one :happy:
Side note :
pizza capers FTW
I may be able to get my hands on some stocker 33 ones. Would that help?
Mechanical issues fall outside my area of expertise.
Side note :
pizza capers FTW
+1
I was just after the technical terms sheesh
Jason's blown a turbo seal from his mega super infinity boosto!
Is that technical ? :happy:
That would be my guess also, but its just a guess.
The flux capacitor has deteriorated causing a feedback interference loop with the syncromesh gear ionisation device, resulting in dilution of the mechanical lubrication fluid, causing it to evaporate in the combustion chamber and/or bypass the piston sealing devices.
Define technical :thumbsup:
dont fit.
Now THAT is technical
It's like... putting too much air in a balloon... and... something bad happens!
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
