Looks like a few newbies. shame I miss out
yet again
Nice work above and beyond thanks GaraGe31.
What are you doing in here Rangamister? Aren't you s'creaming it up ?
Martin: I left a message for the guy with the crashed GTV. I'll let you know if he gets back to me.
Tristan: Can you please have a look and see if you still have the rear speed sensor from your 32?
yeah, had planned to get out there, but ended up having a few too many drinks to drive there
instead sat on my couch and played modnation racers. whoooo :)
So i get into the office, fook all works. Server is missing. Turns out its been changed, upgraded - Who knows. When? Should be done around miday.
me - so we're all doing what until then?
Office - Well the net still works...
ROFL
I REALLY want to post this on the lowballer forum:
I'm teaching a young girl how to drive and she just can't get the hang of putting clutch in before changing gears.
It's just nature's way of telling her she should get back in the kitchen
:blush:
But I have my mod hat on and not sure if I should...
Edited by Smity42
same hey
I'm researching brake options for project alfa. I don't think the 32 brakes will work :blush:
Why is it a no go?
lol. You're a mod over there?
Why is it a no go?
Too small for the front (sounds crazy I know, but if I'm going to customise the brake setup I'm not going to do it half a*sed), too big for the rear.
Theres some 4 piston 330mm alfa brembos on ebay I'm keen on.
Jawol. Sucks being a mod, I'd have posted it in an instant if I wasn't :blush:
I give it about 10 mins tops till I think "f*ck it" and post it anyway.
Jawol. Sucks being a mod, I'd have posted it in an instant if I wasn't :(
Yeah needs more 355mm rotors and big 6 pots. :blush:
Link to thread and I'll post it lol
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
