That would be cool. Next time I have her I'll let you know. You can come and have a look around anytime but it has to be either on a afternoon 3-11 or a late 11-7.
We should do it on an 11-7 Thursday :sick:
I'll see if I can steal Jack next time you've got her :action-smiley-069:
17th of june ?
as long as you wear a ninja mask when you do it and run away with him under one arm :)
No car... but if anything probably the cheapest thing I can get :sick:
t-shirt ninjas ftw... but not t-shirt ninja pedobear O.o
Martin would like it here... I'm staying at a university college and its full of not-quite JB. :action-smiley-069:
correction: they've just finished exams, so make that very drunk not-quite JB.
Edited by GTTG
irection!!
Will Geoff deliver ? :sick:
Will Jason fall asleep at work ?
Will John get his Ninja shirt ?
Will Tim enjoy his breakfast and will Colin ever be able to go near a 20 watt bulb without getting 3rd degree burns?
Stay tuned...
see this is why we need msn... you don't say that kind of stuff there. You just ask me to turn on my cam :action-smiley-069:
Yeah but that's different. We wear wizard hats and robes when we msn. In here I go pantless.
Doesn't have the same feel. :sick:
I'm calling it a day, so I bid you good evening, gentlemen.
Nothing stopping you both breaking out those wizards hats after all.... maybe even the cookie-wands?
    • Yea got me coppers. Bad news is I just put them in and the car still has the light and shakes. I also noticed I hear like rattling coming from the exhaust piping right under me. Does 21 also have a possibility of being O2 sensors?   So, coil packs are good, the harness is good, the MAF is working, and obviously the spark plugs just replaced and working.
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
    • @Rusty NutshI mate. Do you have a pinout diagram for the na neo auto ecu?
    • Yeah thats the plan now. 🤞
    • Have a chat with the tuner, you'd want to drive the car straight there.
