Will Geoff deliver ? :action-smiley-069:
Will Jason fall asleep at work ?
Will John get his Ninja shirt ?
Will Tim enjoy his breakfast and will Colin ever be able to go near a 20 watt bulb without getting 3rd degree burns?
Stay tuned...
Screw you guys :sick:
Morning mangs. Messy night, messier morning. Nothing to do in work though. Epic late night whoring btw.
I meant it with affection :action-smiley-069:
It's what we do best...apparently :)
Morning :)
Morning mangs, solid effort last night
(that's what she said)
True. Tim will appreciate having something to read when he gets to work :sick:
Yeah working on a saturday, I do that all the time
Actually - I just realised that it's Saturday, and he won't be at work. It'll give him something to read with breakfast instead :)
MMM time for breakfast soon :)
You never showed it to me :(
He loves us more
Come in tonight
That's what she said
Martin would like it here... I'm staying at a university college and its full of not-quite JB. :P
correction: they've just finished exams, so make that very drunk not-quite JB.
Hate you
pics
or
+1
Stay tuned...
BAHAHAHAHA
that's loads.
Jesus christ, do I read that correctly? Over 10 pages overnight??
f**k you guys need lives!
Hahahahahhaa but well done!!!
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
