Corner desk ?
I'm in the corner (also under the stairs) but don't have a corner peice on the desk because it is too small :)
Pics?
Will try to grab some tomorrow when I'm in early
I Thought SAU had made been PWNED by the intertron filters for a bit there, but it seems to be OK now ;)
So farken sleepy
and this weather is killing me. Is it just me, or is anybody else constantly hungry?
I am eating like I am getting ready to hibernate. Cleaning the fridge out....
Has anybody got all the Pacific episodes that they can bring on Thurs?
Missed the first couple of episodes when I was o/s, and been wanting to watch it
awesome at batting?
yer we already know that.....
Awesome at tossing too! 2 in a row now :P
there is no name on the trophy... :blink:
could be anyones, could be straight from the trophy store...
Could be, but isn't :(
yeah b*tches
I am awesome
you know what i notice in this pic?
the open, yellow, msn thingo flashing
and guess what
thats probs me trying to say hey
you never reply :blink:
